any way to know if my 1980 928 has LSD?
ftp://928m:928m@12.234.229.133/insta...CupInstall.pdf
...and I have the engine and torque tube in the car as you can see here:
...so I will see how I can tighten it up (with help from inside the car).
Hello Landseer....I wonder if you can help me.....my car hasn't got the LSD but I have now found a used gearbox with LSD (my old gearbox is kaput, it's a long story).
1. Can I just plug and play the LSD gearbox into my non-LSD car?
2. You mentioned "LSD units are modular and can be swapped in and out." Can I just then remove the LSD parts in the gearbox if I do not wish to have the LSD fitted to my car?
Thanks a million!
DIN
Kuala Lumpur
Thanks a million!
DIN
Kuala Lumpur
Thanks a million!
DIN
Kuala Lumpur
Thanks a million!
DIN
Kuala Lumpur
Thank you Joe. Not that I do not want the LSD but rather I'm thinking it could be dangerous for me should the LSD-gearbox does not work well with my non-LSD-transaxle? Perhaps the rear tyres would unnecessarily lock or give way at certain speeds when cornering.
Not sure what you are worried about. It's a clutched unit. It slips some when needed, but puts torque to both wheels no matter what. It can't lock up.
As noted, there were different units. If you are doing a direct swap (same year & model of trans) they should bolt right up.
Different years may be a different story.
Archive Gatekeeper
Still worth borescoping through the fill hole, but there's no " /12 " after the G28.03, so it should not have LSD if it's all original.
Basic Site Sponsor
Basic Site Sponsor
And unless you drive the car in snow/ice, you will never know the difference if it does or does not.
The only exception for the above statement is that at the very limits of the car, when it was very fresh and not very old, a limited slip increased understeer. (Which Porsche dealt with by using a smaller front sway bar than on the later models.)
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Finally got around to rear diff drain and fill since it was a balmy -5C.....Successfully removed all drain and fill plugs (thank-you impact wrench), front plug was only plug with magnet. Video of borescope confirms non-LSD diff.
