928 Forum 1978-1995
Sponsored by: 928 Specialists
'84 Euro S interference or not. Answer will be coming...
Old 02-15-2011, 04:57 AM
  #31
993turbo
993turbo's Avatar
Originally Posted by mark kibort
euro pistons have valve cuts of 9mm deep, exhaust, vs 11mm deep intake. vs the 4.5mm of the euro 85, and the 5 liter 2 valve conversions. so obviously, now you see that the early euro S engines are non interference. contact with euro S 85 is at .3" or 7.6mm valve depression and a 4.5mm valve pocket. so, even with make that valve pocket a euro depth, of 9mm min, you see that you would have clearance up to .6" valve depression. way more radical than any cam ever used on a 928 valve train.
So, all euros are non interference.
Great info Mark.
Do you have the official information on the lift on the ROW S cams 80 - 83 and 84 - 86?
I can only find the duration figures in the WSM and Tech spec book.
Cheers.
Old 02-15-2011, 06:26 AM
  #32
tilac999
tilac999's Avatar
ROW '84 and '85 are the same or different? I'm confused.
Old 02-15-2011, 06:37 AM
  #33
Landseer
Landseer's Avatar
Here is what we think is an early Euro S piston (lifted from Gunar's thread)
Old 02-15-2011, 06:59 AM
  #34
993turbo
993turbo's Avatar
Many are confused.
If you see my post above, I list the engine numbers change overs, for both Auto and manual ROW S cars. This happened somewhere mid-84 model year.
The only difference is a slight change to the pistons.
Old 02-15-2011, 07:02 AM
  #35
993turbo
993turbo's Avatar
Landseer, this would be a tolerance 1, 97mm, 80 - 83 ROW S (and some 84 ROW S,up to the engine numbers I posted above)
Old 02-15-2011, 07:13 AM
  #36
Landseer
Landseer's Avatar
So, are you saying that if the pistons are installed in the correct orientation within the engines, that no EuroS cars theoretically are non-interference?
If not interference per se, are there operation conditions that would cause collision?
Like, as the belt breaks under load, engine RPM jumps and rips the cam belt across the DS bank at such an elevate speed that it accelerates the valves to float into the pistons?
Or carbon build-up can sum to greater than the gap distance?
Just trying to learn here. Why are we having the dialogue if the engines aren't interference? Isn't there some history of Euro belts breaking and valves bending? ( I'm glad that DougM posted the question / interesting / hope his valves aren't damaged, BTW)
Old 02-15-2011, 11:02 AM
  #37
dcrasta
dcrasta's Avatar
Originally Posted by porschedonald
Since this is kind of a break belt thread I do have a question.
There is a difference in a belt breaking on a 16V 928 engine vs. a 32V engine right ? And what would some of those differences be ?
Some 16v motors (non-interference) the belt breaks, you cry a little, and you can fix it ($..)
All 32v motors (Interference!!)' the belt breaks, you cry like a baby because you know this is pain , real pain. You 'can' fix it but prepare for valve damage, piston damage, real $$($$$$$$).
So - Don't break your cam belts! They only break from neglect or improper repair.
Old 02-15-2011, 01:02 PM
  #38
mark kibort
mark kibort's Avatar
so, you have the two different pistons shown on this thread now. (thanks Glen)
euro 80-83 deep cuts
euro 84 to 85, shallow cuts
euro 80-83 non interference, because the valve pocket is near .5 deep! total lift of the cam is somewhere in the .4" range, and if you depressed a valve in the head of an assembled motor, you would see that the valve is pushed down .3" and it touches the piston, with euro 85 valve cuts. this means, if you have .2" of a deeper pocket, you have clearance up to .5" lift with no problems.
break the belt, nothing will happen.
Old 02-15-2011, 01:04 PM
  #39
mark kibort
when the belt breaks,the valves stops, or continue to spin at some out of orientation timing due to stripped teath on the belt, which is how it usually "breaks". the valves are going up and down and at .3" the would make contact on an 85 motor, on a 82 motor, they would would have to be pushed down .5" which is greater than the cam lift.
so, no interference in a euro 80-83 motor
Old 02-15-2011, 01:05 PM
  #40
mark kibort
same lift. devek posted the lift a long time ago. I have it written down or on my computer. ill look
lift is the same for both cams!
Originally Posted by 993turbo
Great info Mark.
Cheers.
Old 02-15-2011, 01:19 PM
  #41
Tampa 928s
Tampa 928s's Avatar
I just looked at my euro 85 82E 05721 does this mean a lower compression ratio?
Old 02-15-2011, 02:01 PM
  #42
mark kibort
80-83 is the lower compression ratio 10:1 vs the 10.5 or so for the euro 84-5
Old 02-15-2011, 04:16 PM
  #43
993turbo
993turbo's Avatar
82E 05721 is a 84' model year engine. If it was an 85' model year engine if would be an 82F xxxxx
84 = E
85 = F
86 = G
It always helps if you write the engine type as well. M28/ 21? or M28 / 22?
Old 02-15-2011, 04:22 PM
  #44
993turbo
993turbo's Avatar
the compression ratio is 10,0:1 for the engines in the 80 - 83 ROW (euro) S.
10,0:1 is also the compression ratio for the EARLY 84' model year ROW S (S2) with LH-jet. The change to the 10,4:1 pistons were at the following engine numbers ( as I wrote in my previous post )
M28/21 82E 00596
M28/22 82E 06114
the change to the new 10,4:1 pistons happened sometimes in the middle of the 84 (E) model year.
Old 02-15-2011, 04:24 PM
  #45
993turbo
993turbo's Avatar
I would be very happy if you managed to dig up the lift numbers. It saves me some measuring.
Quick Reply: '84 Euro S interference or not. Answer will be coming...
