928 Forum 1978-1995
Sponsored by: 928 Specialists
'84 Euro S interference or not. Answer will be coming...
Old 02-15-2011, 05:49 PM
  #46
DougM
DougM's Avatar
I am making some progress pulling stuff off. Had a few hangups. Just had to pick up a 5' piece if iron to get leverage to break the crank bolt free. Now I need to rent a puller to get the balancer off.
Reading through this, I wonder if I did internal damage.
Engine number is: m28/21 82E 00528
Heads are 928.105.251.1R
Messy...
Old 02-15-2011, 05:51 PM
  #47
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Originally Posted by 993turbo
I would be very happy if you managed to dig up the lift numbers. It saves me some measuring.
This has been floating around for a while. I started a larger chart that included engines and other specs, no idea where I put it.
Old 02-15-2011, 06:04 PM
  #48
tilac999
tilac999's Avatar
So before mid-'84 you're safe. Right?
Old 02-15-2011, 06:10 PM
  #49
DougM
DougM's Avatar
That is what I am wondering. If so, I may just get it all cleaned up, put the timing belt back on and run a compression check.
Old 02-15-2011, 06:26 PM
  #50
mark kibort
mark kibort's Avatar
there you go. near .5" of lift, and with euro 85, you have .2mm of contact. not good. but with 82, you have no contact,becuause the pocket is deep enough to handle .5" of lift
Old 02-15-2011, 06:40 PM
  #51
993turbo
993turbo's Avatar
Messy...
Provided that the engine is stock (stock pistons / cams) you should have no internal damage.
Old 02-15-2011, 06:41 PM
  #52
993turbo
993turbo's Avatar
Great info!!! Cheers! Saved me some time on the dial guage.
Old 02-15-2011, 07:27 PM
  #53
DougM
DougM's Avatar
So what is the true HP and torque of this motor assuming internals are stock? I guess it is not really like the '83 down, but doesn't have the higher compression of the '84 up?
Also, I guess I will clean it up, put a belt on and run a compression check to verify. I may also get a boroscope and fish it down some plug holes and have a look.
Old 02-15-2011, 07:37 PM
  #54
Hilton
Hilton's Avatar
It should be at least the factory-rated spec. of 310hp flywheel - Porsche didn't usually lie about their power output (at least on the downside).
Which would explain why some of the stock 85 16V cars I've seen on dyno's put down such large numbers (similar numbers to stock S4's with no knock/hall faults). With their higher compression, they're probably pushing a chunk more hp than the early 84's.
I still want to own a decent '86 16V at some point.. the car with it all - earlier style, S4 brakes, high compression revvy 16V motor etc. Just need to find me a no-sunroof 5-speed one
  #55
txhokie4life
txhokie4life's Avatar
you should be able to do a compression or leak down test and know pretty quickly.
m
Quick Reply: '84 Euro S interference or not. Answer will be coming...
