RE: max jack lift
RE: max jack lift
hey guys,
does any one know if anybody bought one, i like to get some feed back on it.
iam kind of intrested but dont know to much about it. i heard one of the
members on rennlist has one. please let me know. Ed.
A bunch of us went in on a group buy for the maxjax so far I 'am very happy with it, only complaint is the hoses supplied are on the short side, I just added 10' so I can keep the pump on one side of the garage instead of in front or back of the car. If you have a tall garage I would go with a normal 2 post lift so you can standup vs sitting in a chair.
More info here:
https://rennlist.com/forums/928-foru...ill-close.html
More info here:
Chronic Tool Dropper
Have one from the group buy, and use it regularly. I'll echo the comment about needing a hose extension. Also bought extra concrete anchors so I can put the columns at different spacing for different projects. I'll confess that I pretty much leave the columns at widest spacing, since it allows easy parking, and work on the car is possible with the doors wide open. Being ablre to unbolt the columns and move them means that I can use the garage bay for other things.
The deal from Costco that started the group-buy discussion is no longer available from them.
Quick Jack
I went ahead and bit the bullet for a quick jack. I placed the rubber? Blocks under the frame rail in the front and at the rear trailing arm pivot in the rear. Quickjack doesn’t tell you how to route the hoses well in the instructions. Whatever you do, route the hoses to the outside of the car between the rubber blocks. If you run them out the front of the side frame you’ll pinch the hose. Not cool. Just keep the hoses clear of the side frames, and out between the rocker panel and the top of the frame and you’ll be OK. I had my early 944 up on them for several months and found them to be quite stable and sturdy. They are heavy… but I still like them a lot😀. Thanks
I have the 7000, and it's great. It doesn't get up as high as a scissor lift, but it keeps the center of the car clear and it's reassuringly stable. I've used it many, many times.
^^^Totally agree. If your workspace it height challenged and you can't fit in a full-height lift, this is the way to go. I also love mine
You may need to change out the quick disconnect fittings for better ones that don't leak and extend one of the hydraulic hoses to get the pump unit to the side for convenience but after that you are set.
I love mine, too.
I had my local hydraulic shop stop by and add a length of hose so I could run it over the rafters.
KB
KB
Mine in action
I got a 7000 on clearance, which $500 cheaper than the next lower model that was on sale at the time, love it.
I just drive in and park over it..
I echo the concerns on using stacked blocks...dont. Very unstable..like the car is sitting on jello.
ive had mine for many years now; only add was the extended hose that goes up and over garage rafters so it can be operated from the side.
works great, fantastic piece of equipment for working on all types.
Archive Gatekeeper
+whatever on running the crossover hose up top, I put mine through a 2" pipe in the ceiling.
The only bad part of my MaxJax (now ~10 years old and has had a car on it 90+% of the time) was the QC on the stickers that came on it.
