928 Forum 1978-1995
Sponsored by: 928 Specialists
Do not use the in-tank pump... EVER
Old 04-30-2011, 08:28 PM
AO
Supercharged
AO's Avatar
Default Do not use the in-tank pump... EVER
So today I pulled the in-tank pump from my car. This was installed new, two years ago! This is what it looked like when I pulled it out today...
Old 04-30-2011, 08:38 PM
Jadz928
Jadz928's Avatar
Had you replaced it with a screen yet?
Old 04-30-2011, 08:42 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Why do some cars have both?
Old 04-30-2011, 09:01 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
It was added for hot climates and low vapor pressure fuel. AFAIK, people have removed them from all models of the 928 with no adverse affects.
The hose failure and the drive pin failure on the pump are likely due to Ethanol additives in modern fuel. Quite often these cars sit for a long time and the fuel will begin to separate.
Old 04-30-2011, 09:06 PM
Maleficio
Maleficio's Avatar
Wow. With ethanol in the fuel now, I guess Kevlar-based tubing would be a good choice.
Old 04-30-2011, 09:11 PM
Ducman82
Ducman82's Avatar
i always wondered about that second pump. its not like a "back up" that you switch on after the other dies...
Old 04-30-2011, 09:22 PM
928 at last
928 at last's Avatar
What king of fule are you pumpin' through that thing Andrew????
Local guys recycycling evil stuff thought the gas pumps now? (You sure Brian hasn' t been near yer car ?)
Hell hath no fury......
Old 04-30-2011, 09:23 PM
928 at last
OK,
ONE MORE TIME FOR THE AUTO SPELL CHECK!!....
FUEL...Dammit.
Old 04-30-2011, 09:43 PM
the flyin' scotsman
the flyin' scotsman's Avatar
what 'king' u talkin' 'bout Rob
Theres a description in the '89 S4 technik supplement...
Old 04-30-2011, 09:56 PM
BC
BC's Avatar
Essentially correct. That rubber sitting in fuel can't be good. Especially if the fuel is over 10% ethanol you could have some softening of the rubber if it is natural rubber. If it were a flouro derivitave of some sort would be better.
If the pump flows the fuel past the windings and they are not covered, then the copper can corrode from the water in the 10% ethanol.
The 10% should not be catastrophic in two years. I believe that there has been ethanol in fuel for quite a while, and they did not fail as often when first installed.
It's a quality issue. But with older cars not designed for ANY alcohol in the fuels, there will be issues even with the newer parts.
The strainer assembly is a much better option for this area
Old 04-30-2011, 09:58 PM
BC
BC's Avatar
Just more use of non rubber replacements. Teflon, viton, flouro-elastomers, if I remember that name properly.
Old 04-30-2011, 10:06 PM
jcg928s
jcg928s's Avatar
Rubber in fuel tanks is not all that uncommon. The last few cars I have put larger pumps into have had rubber lines submersed in the tank and show no signs of cracking and what not.
That is a very disturbing photo though.
Old 04-30-2011, 10:15 PM
svp928
svp928's Avatar
Quit with the Benzine, Andrew..
I'd think you are OK without that pump- don't you have the 044? Should be fine.
Or, switch to straight nitro..hehe
Old 04-30-2011, 10:51 PM
BC
BC's Avatar
I think its a matter of the manufacturer not updating the materials for these pumps.
Old 04-30-2011, 10:52 PM
928 at last
Default AARRGGHHH!
For the love of........
Quick Reply: Do not use the in-tank pump... EVER
