928 Forum 1978-1995
Sponsored by: 928 Specialists
The build a 928 boat thread.
Old 06-23-2011, 12:00 PM
  #31
Tass 928
Tass 928's Avatar
Originally Posted by DR
Funny you say that...when I was looking at the Engine/Air Inlet Pics, the first thought was Dave is going to need at least some sort of braces at the front of that airbox to somewhere on the engine/block/heads. I hadn't thought about the bouncing, but just the air drag alone will break the rubber mounts on the Air Guide.
So yeah, you should do some sort of rubber mounted supports for the "offshore airbox"...I would do front and rear supports from the corners of the airbox if it were me.
OH, and dump the factory air filter for a K&N type 928 Filter, it will hold up better with all the moisture.
Cheers,
Dave
Dave,
I agree that the airbox will need some addtional mounting points. The picture was taken during a test fit. It took a lot of trial and error to get a design that would give me the same cross sectional area has the stock inlet yet still go on and off without taking anything else apart.
The (poorly worded) question I was asking was will there be a negative effect on the assembly shown below in red?
Old 06-23-2011, 12:54 PM
  #32
Joe Twill
Joe Twill's Avatar
Interesting question. I've never worked on or seen CIS apart, but I'm glad to offer an uninformed opinion. The rectangle at the right end of your red circle is a counterweight to balance the mass of the plate and lever, so up/down accelerations are inertially balanced and skipping along the water won't move the air flow sensor. Porpoising might have an effect, but you'll trim the boat out of that. If the bow rises when running, the mixture might change a little (rich?), like driving up a steep hill. So maybe you're thinking adjust the mixture with the boat on the trailer with the bow up at about the running pitch?
Old 06-23-2011, 12:56 PM
  #33
DR
Rennlist Sponsor
DR's Avatar
Originally Posted by Tass 928
Dave,
Concerning that...well I think you are going to be the one to find the threshold of what that will take with lots of "bouncing" and sharp impacts associated with a (fast light) boat on the ever changing water conditions.
But, roads are not smooth and jar free and have lots of sharp impacts etc...so I would would put that worry on the "B" list for now....or at least until you get some water time to see if you have running issues under harsh conditions.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 06-24-2011, 09:03 AM
  #34
Tass 928
Tass 928's Avatar
I'll try to post pictures of the various components that are going into this project. These pictures show the parts that will take me from the 928 crankshaft to the splined jet pump shaft. The original Porsche marine kit was set up for use with an inboard/outboard drive so I put some of those parts on the shelf and created some new parts to suit my application.
Old 06-24-2011, 02:41 PM
  #35
sharknoob
sharknoob's Avatar
Tass,
I am a member at OffshoreOnly.com you should post over there too. You will get any answers you need, and they love build threads
Old 06-24-2011, 04:02 PM
  #36
Tass 928
Tass 928's Avatar
Originally Posted by sharknoob
Tass,
Thanks for the tip, I'll check it out.
I have been monitoring Performance Boat , Scream & Fly and Boat Freaks.
There is a lot of usefull stuff on the forums.
Old 07-07-2011, 09:32 AM
  #37
Tass 928
Tass 928's Avatar
Default An update 7-7-11
The project moves forward....
While I am waiting for my fiberglass guy to visit and give me an opinion on restoring the exterior finish, I cleared a spot in the garage and brought the boat indoors.
The trailer is a project in itself and since it's basically a big lump of welded steel structurals, I can refurb that without much trouble.
The first step was to get the boat off of the trailer so I made simple cart that has heavy duty swivel casters, brakes and proper support for the hull.
Old 07-07-2011, 09:38 AM
  #38
Tass 928
Tass 928's Avatar
I tied the boat to a solid anchor ( car lift posts) and pulled the trailer out from under it. As the trailer came out, I slid the cart under the boat.
Here is the boat resting on it's new cart. It moves around very easily and will probably stay on the cart for the duration of the project.
Old 07-07-2011, 10:06 AM
  #39
fredfox
fredfox's Avatar
Not to hijack the thread but...
I was on this boat in the bay off of Seaside NJ and I swear I will never go on it again.
120 is way too fast, 180 is insane.
Old 07-07-2011, 10:33 AM
  #40
Tass 928
Tass 928's Avatar
Here is the trailer....pretty basic. It will get sandblasted and then epoxy coated in black. I'll probably just buy a set of chrome fenders for it. The hubs and brakes will be rebuilt and the axles will be widened so I can run the deep offset 928 wheels.
Old 07-07-2011, 10:43 AM
  #41
Tass 928
Tass 928's Avatar
Before I tear the trailer apart, I did some trial fitting of the 928 wheels so I could measure for fender and boat clearance.
Working with what I have "in stock", I'm looking at phone dials and 10x18 turbo-twists. The turbos have 285's mounted and might present some clearance problems. I need to keep this narrow enough to get through the garage door.
I also think the phone dials are more in keeping with my intended 928 theme.
Old 07-07-2011, 10:46 AM
  #42
Cosmo Kramer
Cosmo Kramer's Avatar
I like the twists! Get some fronts in 8" they will fit much better.
Love your project btw!
Old 07-07-2011, 11:17 AM
  #43
Mike Frye
Craic Head
Mike Frye's Avatar
OLD SCHOOL BABY! Gotta be the phone dials!
Love this thread!
BTW- Will the cart still be OK when you put the engine in and the center of gravity shifts or will it be back on the trailer by then?
Old 07-07-2011, 02:11 PM
  #44
James Bailey
James Bailey's Avatar
It might be nice to run 15 inch phone dials....there is a much better trailer tire selection and less expensive than 16 tires. I tend to prefer running real trailer tires for a number of reasons......including that the higher sidewalls smooth out the ride and beat up the boat less and they track better than auto tires due to their construction.
Old 07-07-2011, 02:39 PM
  #45
Tass 928
Tass 928's Avatar
Hey Jim
I agree with all of the above but...I'm giving up a little practicality for the sake of design. My gross weight should be well under 1,500lbs and I'm spreading that over 4 wheels.
The reason I selected 16" is that I have a 10 of them here already and I would have to buy 15" if I wanted to switch. Same story with the tires. I have a few sets of tires here that are dying of old age rather than wear.
Quick Reply: The build a 928 boat thread.
