6E171 AC compressor leaking oil?
I just got it togather a month ago and while sliding under this weekend to tackle the forward shift cup I noticed oil collecting (assume ester as that is what I put into it and it has a green tint from the leak detector stuff previously installed- not by me) across the bottom of the compressor at each joint.
I am guessing the seals are going. Is this a typical failure mode? Suggestions on sources for a rebuild kit assuming they come withj the seald for the middle and front and back caps?
Thanks Bill.
It seems the compressor has oil accumulating at both end cap seams and forms at the center seam as well. Has anyone rebuilt a 6E171? The link provided doesn't look like it has seals for all thye leak points I seem to have.
I just resealed mine this past weekend with plans to finally get the A/C working in it. There is a seal for each end cap, a gasket on each end, a center body seal and a carbon seal on the shaft. You will need to order the body seal kit and the shaft seal separately as there is no complete kit that contains them all. It's a very straight forward process, not complicated to do. Just remember the key is absolute cleanliness.
Under the Lift
That 6E171 kit may not be complete. They also have gasket kits and there are other sources as well.
http://www.acsource.com/nippondenso_1.aspx
I have resealed my 6E171 successfully. However, I recently failed on a 10PA20 (later model) - leaked from every seal after I finished even though I did a careful job.
Under the Lift
Bill, have you done a post mortem on the 10PA20?
Curious, as I have at least 2 case leaks. No hurry for me - I live in the UK - so this'll be a winter fix project.
Oliver
Oliver
I can't say. The compressor I have came off Brian's Sexual Chocolate car. I had it tested by the same place that did my lines in Austin and they said the pump and clutch were good but only text upto about 125 PSI.
I did convert my system to R134 and ester oil so not sure if that has anything to do with the seeping from the compressor joints. It still works but I dojn't want to destry a good compressor by letting it got to long.
Under the Lift
No, I don't know what went wrong. EVERY seal/gasket/o-ring leaked. It was Nicole's compressor. She bought a new one rather than fuss with it any more.
