928 Forum 1978-1995
Sponsored by: 928 Specialists
POD unknown connections
Old 07-20-2011, 04:49 PM
Pappy
Pappy's Avatar
Default POD unknown connections
87s4 a/t I have the no reverse lights and no prnd32 indicator lighting issue. I've read up on it and started to tool around with the car this afternoon. Stumbled upon some unknowns: 3rd pic what is this button? The 2nd pic is trying to show the brown/white and brown wires to no where.
Old 07-20-2011, 09:41 PM
Pappy
Pappy's Avatar
Finally, after searching for periods of time throughout the day, I've found out what most of the connections are for. The one that I am still not sure of is from the first picture. It's the connection to the right/bottom of the pod.
Old 07-20-2011, 09:45 PM
Ducman82
Ducman82's Avatar
i believe that is for a rheostat that controls wiper speed....
Old 07-20-2011, 10:15 PM
jpitman2
jpitman2's Avatar
I also have a taped up switch socket, but the wire colours are different...balck/blue , and some browns.
Used to have Euro rear fogs in the bumper, gone now, but the switch taping looks factory, like yours.
the spade tag females do look like those on my wiper speed, dash light dimmer.
JP 83 Euro S AT 53k
Old 07-20-2011, 10:21 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,278 Likes on 1,263 Posts
the barrel connector wrapped in tape is for the rear foglamps and the USA cars do not have this system connected .
the other connector in the first picture looks like the connector that plugs into the little area between the ignition cylinder and the steering column,
it tells if the key is in the ignition ,
the blue and brown wires just sit loose.
BUT check the rheostats to see if they are both connected the one on the left of the steering column is for the light dimmer yellow wires and the right side is for wiper speed delay also there is a push button this one will have very small female connectors with black wires its for the intensive washer also on the right side.
Old 07-20-2011, 10:23 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
JP if you have a barrel connector and you have a Euro,
then this one is for the odometer reset on the Euro.
NOTE this connector is not used but rather rerouted to a push button on the bottom edge of the pod to reset the trip odometer
Old 07-20-2011, 11:25 PM
77tony
77tony's Avatar
I knew MrMerlin would know. I would have tried plugging it in to the 9 pin connector to tow a trailer. T
Old 07-21-2011, 08:15 AM
Leon Speed
Leon Speed's Avatar
Yes, looks like this is one mistery that is not yet solved.
Old 07-21-2011, 12:43 PM
Pappy
Pappy's Avatar
The first pic, the connection circled at right was the culprit.
Was not connected and resulted in no prnd32 and reverse lights. Connecting this back remedied this and shut off the false ABS warning light. Good to go now!
Old 07-21-2011, 10:42 PM
mpesik
mpesik's Avatar
You have nice clean unblemished hands.
Are you a hand model?
Quick Reply: POD unknown connections
