quick wheel question
I hVE 1980 928 and was looking at getting a set of 18x8 wheels off of a 2008 Cayenne. The offset is 57. I think these should work up front ok but for the back would they work or would I need a spacer??
Team Owner
I would not suggest these wheels as they are the same size front and rear there are better choices ,
the front size is good the rear size is not wide enough the offsets will work front and rear and you may be able to add a bolt on spacer to the rear
