928 Forum 1978-1995
Sponsored by: 928 Specialists
Alternator backing for exterior a/c sensor
Old 10-05-2011, 07:30 PM
joejoe
joejoe's Avatar
Default Alternator backing for exterior a/c sensor
Looking at replacing the paris rohn alt on my '81 (was marshal before) and am wondering what are people doing with the outside temp sensor when no cover is used? Do you just leave in hose with no air flow?
Old 10-05-2011, 07:36 PM
SeanR
SeanR's Avatar
The sensor doesn't get it's air from the alternator, it flows just the opposite.
Old 10-05-2011, 07:55 PM
joejoe
joejoe's Avatar
Sean is the ducting connecting to the alternator necessary?, or can the ducting be left open. Will leaving not connected to alternator cause a problem with a/c?
Old 10-05-2011, 08:00 PM
ZEUS+
ZEUS+'s Avatar
The sensor is just an outside/ambient temp sensor. Secured properly it will be fine, but the alt. will overheat without a hose. It was mounted in the alt. coolant hose because it a good source for fresh air. The fan in the alt. helps to draw in the fresh air and discharges it out the front to keep the alt. cool.
Old 10-06-2011, 10:20 AM
ROG100
Basic Sponsor
ROG100's Avatar
Alternator will in theory overheat. Warranty states no returns for overheat failure.
Cover is circa $30 and the ducting $25.
Old 10-06-2011, 10:48 AM
GlenL
GlenL's Avatar
Leave the temp sensor alone.
Without belly pans you don't need a cover and hose.
Old 10-06-2011, 08:36 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Without the cover and hose, the alternator is being "cooled" with air from around the exhaust manifold. Oil from any power steering leak adds to the mix.
Quick Reply: Alternator backing for exterior a/c sensor
