928 Forum 1978-1995
Sponsored by: 928 Specialists
Everything new and car overheats
Old 11-12-2011, 07:31 PM
DougM
DougM's Avatar
Default Everything new and car overheats
Finally had a chance to drive the car around the neighborhood after a complete engine out refresh. Engine started to overheat after a few miles and spewed coolant. After cooling down, added more water and burped the system. Tried it again and the same thing happened.
WP is new, not rebuilt
All seals and o rings in the water bridge are new as well as the thermostat.
A couple of observations right after shutdown.
Upper rad hose hot
Lower rad hose not quite as hot.
Radiator warm.
Once cool, it is easy to squeeze the lower hose to burp the system.
When it was hot, right after shutdown, it was difficult to squeeze the lower hose like it was full of pressure???
Old 11-12-2011, 07:37 PM
pjg
pjg's Avatar
Check for radiator blockage.
Old 11-12-2011, 07:41 PM
IcemanG17
IcemanG17's Avatar
thermostat backwards...................................don't ask how i know
Old 11-12-2011, 07:53 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,280 Likes on 1,265 Posts
did you have the heads off?
Did you backflush the radiator with a hose after you removed it?
to fill the 928 cooling system,
with the car level
fill the bottle to just above the seam in tank,
then start engine turn on the heater to full hot,
run till the fans come on or for 10 mins till the thermostat opens,
both hoses are hot use an IR gun to test for temps. looking for about 185 top hose and 165 lower hose.
replace the cap drive the car for 5 miles with the heater on,
park it let it cool,
top up the system as necessary
Old 11-12-2011, 07:54 PM
DougM
DougM's Avatar
I was wondering if that could be it. Will pull it out and check tomorrow.
Old 11-12-2011, 07:59 PM
DougM
DougM's Avatar
Never took the heads off because they had just been off the car and freshened just before I got the car.
Radiator is a newer(2 years old) aluminum 928 Motorsports one. I did flush it with water when removed months ago.
with the car level
Old 11-12-2011, 08:00 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,076 Likes on 1,185 Posts
yup.
Did you replace the seal that goes behind the thermostat?
Old 11-12-2011, 08:03 PM
IcemanG17
IcemanG17's Avatar
Mine ran sorta cool with it backwards...only after 2 hours on track in reasonable temps did it finally overheat.....of course having Mark Anderson himself on your team helps...."Is the thermostat in correctly?" he asked...me "I dunno"...it wasn't....be fine ever since...
Old 11-12-2011, 08:42 PM
ColinB
ColinB's Avatar
First check the thermostat and gasket as others have suggested. If that's not your problem consider this: I had the same symptoms on my '89 car. It would overheat within 5-10 minutes. Turned out the coolant wasn't circulating because the water pump impellor had become loose on the shaft. I was told by the mechanic that it was a fairly common occurrence even with OE water pumps.
HTH
Colin
Old 11-12-2011, 08:52 PM
DougM
DougM's Avatar
I will first do as MrMerlin suggests and try the proper procedure on filling the system tomorrow. If that doesn't work, I will pull the thermostat and check.
Old 11-12-2011, 08:57 PM
Lizard928
Lizard928's Avatar
Pull the thermostat first and test in boiling water.
You will then know its in right and working correctly. Then fill as per MrMerlin.
Old 11-12-2011, 09:16 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
where did you get the waterpump?
what brand is it?
did you replace the rear seal for the thermostat in the water bridge?
Old 11-12-2011, 09:58 PM
DougM
DougM's Avatar
what brand is it?
WP (Lasso? I think)was ordered by a Porsche service owner friend of mine that orders only OEM from the main US distributors. Not EBAY and not rebuilt.
All the seals were replaced in the bridge and the smaller rear one as well.
Old 11-12-2011, 10:19 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
OK then
check thermostat first,
then refill as directed
Old 11-12-2011, 11:28 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
If it overheats that quickly, my money is on the water pump.
Quick Reply: Everything new and car overheats
