928 Forum 1978-1995
Sponsored by: 928 Specialists
Cam Gear Thread
Old 12-04-2011, 06:31 PM
SeanR
SeanR's Avatar
Default Cam Gear Thread
xx
SeanR is offline
Old 12-04-2011, 06:41 PM
namasgt
namasgt's Avatar
It was probably requested to be closed. Since there was some personal bashing.....
I'm not surprised it got removed. Nevertheless, I would like to see results and test data to be comfortable enough to buy them. Have they been installed on any 928 and for how many miles have they been tested? Why would this product be a better buy from the current NEW design from Porsche, since the prices are the same? What will I gain by using these vs the NEW factory ones?
namasgt is offline
Old 12-04-2011, 06:42 PM
SeanR
SeanR's Avatar
zz
SeanR is offline
Old 12-04-2011, 07:06 PM
the flyin' scotsman
the flyin' scotsman's Avatar
missed the original thread.....who is making the alternate to Porsche?
the flyin' scotsman is online now
Old 12-04-2011, 07:18 PM
karl ruiter
karl ruiter's Avatar
Carl presented an alternative that he had build, but it seems he was not aware of the new parts from Porsche, the tooth profile was questioned, and some claims he made regarding advantages were bashed by the usual bashers. I did not look at his price, but I gather it was similar to the Porsche part.
karl ruiter is offline
Old 12-04-2011, 07:26 PM
namasgt
namasgt's Avatar
The tooth profile did look different, a little bit. could have been the angle of the camera. A better comparison would be to put the gears on top of each other, Porsche vs Motorsports, to see if the profiles are the same. The link provided above has the pictures.
namasgt is offline
Old 12-04-2011, 09:38 PM
the flyin' scotsman
thx Roger et al........not taking sides as I didnt see the original thread but one of these days the usual suspects (doubting thomas) will **** off the small amount of excellent suppliers we have today leaving us with nothing but Camrys.
no offense to anyone named thomas unless of course theres also a john involved; Roger will know the rhyme.
Old 12-04-2011, 09:41 PM
BC
BC's Avatar
I have a set I bought new in 2003. I also have a set I have just taken off a 31k mile engine. The coating on the 31k ones are perfect, hard, and green. I will have to figure out what to do with the "newly" purchased ones- they do not look as though they will last.
BC is offline
Old 12-04-2011, 10:21 PM
heinrich
928 Collector
heinrich's Avatar
I just bead blasted and wire polished a used gear. I also brush polished some other aluminium parts like water bridge. Without a doubt, the original gear is the softest aluminium part I have seen. That coating is no more than good powder coat, but once worn off, it almost appears to be designed to destroy the belt.
heinrich is offline
Old 12-04-2011, 11:08 PM
namasgt
namasgt's Avatar
I'm pretty sure the original gears that are no longer available were made from some sort of Magnesium alloy. Probably why they are so soft.
The new gears however could be Aluminum, since they weight more.
namasgt is offline
Old 12-04-2011, 11:15 PM
SeanR
SeanR's Avatar
xx
SeanR is offline
Old 12-04-2011, 11:52 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Everything I've ever ordered from Carl has had some sort of issue. I would never trust him to design a critical engine part for me. If I have the choice of ordering a part from Carl or a part from Porsche for close to the same price, there is no question. I would order the part from Porsche.
Fabio421 is offline
Old 12-05-2011, 02:53 AM
jcorenman
jcorenman's Avatar
It's hard to tell from the pic's, but this might help. I took one of the pic's (as indicated) and did some simple cropping and rotating, to get the two tooth profiles aligned so that they can be compared easier.
For sure the new sprocket is not the same profile as the Porsche sprocket shown in the lower pic-- more "V" shaped vs "U". I do not know if it is significant or not, but it would be a source of discomfort to me.
jcorenman is offline
Old 12-05-2011, 03:36 AM
Lizard928
Lizard928's Avatar
Doing further photo editing, it appears as though the valley has the same curvature from stock to new.
However the walls are much more inclined, this would mean that they would be more prone to the belt teeth slipping out. Meaning that a loosely tensioned belt would be more prone to skipping a tooth or more.
The other thing that was almost impossible to tell and especially from a photo is the depth from the peak to valley. It looks close, but appears to be ever so shallower, which would mean more stress on the teeth of the belt.
Lizard928 is offline
Old 12-05-2011, 04:05 AM
UKKid35
UKKid35's Avatar
Isn't there an alternative belt tooth profile that has a shallow V at the top of the tooth?
I'd be willing to take a chance on Carl's tooth profile, but I can't afford those prices. I'll have to rely on used cam sprockets and a 20k belt change interval instead.
UKKid35 is offline
Quick Reply: Cam Gear Thread
