928 Forum 1978-1995
Sponsored by: 928 Specialists
im new to the forum
Old 12-06-2011, 05:00 PM
nuts4porsche
nuts4porsche's Avatar
Angry im new to the forum
i have a 80 US model 928,auto 93k,not starting but everything works inside and out but no spark! i can jump the coil from battery and she fires right up,with gas poured in the intake,runs great! no smoke or noises or leaks. anyone have a thought? its getting frustrating! all grounds have been cleaned,installed all new fuses,and a few relays,new fuel pump will be del. on thursday. car is driving me nuts,wife wants me to sell,but i want it. any help? thanks
Old 12-06-2011, 05:13 PM
SeanR
SeanR's Avatar
Welcome to Rennlist.
Just to clarify, you pour gas in to the intake and jump the coil with battery power and it runs?
Old 12-06-2011, 05:22 PM
nuts4porsche
yes! starts right up! no issues,but if i dont do that nothing happens, but everything else works-lights,windows,radio,heat ect.
Old 12-06-2011, 05:28 PM
brutus
brutus's Avatar
You bought it like this ? How long since it was a running driving car ?
Old 12-06-2011, 05:37 PM
nuts4porsche
yes,the last time it had tags on her was 99' but the guy said he had it out after that. not sure how honest he was? it is a complete car,only missing rear pass. floor mat
Old 12-06-2011, 05:54 PM
GuardsRedHammerhead
GuardsRedHammerhead's Avatar
Hey, if the wife wins this one, let me know. I will swing down to C-Bus and buy it, for the right price.
Old 12-06-2011, 06:00 PM
nuts4porsche
you may have to do that...lol she hates it! it has the "s" options with 17 inch chrome "S" wheels with new tread,but the og cookiecutters on now,and all spoilers and trim are off and resprayed. the 17's are a seperate sale,just got those! could let her go to good home if $ is right.
ALKada
ALKada's Avatar
Have you checked to see if the fuel pump is pumping fuel??
Old 12-06-2011, 06:04 PM
nuts4porsche
fuel is going to it,but not out,have one on order,will be here thursday.
Old 12-06-2011, 06:39 PM
danglerb
danglerb's Avatar
Maybe an old alarm system?
Listen for the fuel pump running when cranking the car.
Check the ballast resistors and voltage at the coil.
Listen to the injectors while cranking for clicks, test voltage with a noid light.
Have somebody that knows a 928 well look it over.
Old 12-06-2011, 06:41 PM
nuts4porsche
would like to get her running from key start,if anyone has feed back let me know what you think
Old 12-06-2011, 06:52 PM
Lizard928
Lizard928's Avatar
Replace the fuel injection relay with factory part.
As well as install a new green wire.
Old 12-06-2011, 06:56 PM
nuts4porsche
thanks,looking into it now!
Old 12-06-2011, 06:59 PM
heinrich
928 Collector
heinrich's Avatar
chrome S4 wheels are 16". Maybe you have chromed 17's on there but 17 was never an option./
Old 12-06-2011, 07:01 PM
4drgl
4drgl's Avatar
Default Green wire....
Is the signal wire from the ecm.... It's usually not green (bc of age, corrosion, and grease), it leads from the bottom of the distributor to a 2 prong plug somewhere on the passenger side timing cover... don't tug on it either, you will break it... very brittle.
Quick Reply: im new to the forum
