Rear Wheel Bearing..... Dry Grease
When checking my rear wheel bearing i had a bad feeling an decided to pull the bearing (like a rotten tooth)
Suspicion was confirmed the grease was verry dry
Time to get a new one
Under the Lift
A good clue is how the hub spins. If it freewheels, the grease is gone.
/billbmsn?feature=mhee#p/u/5/GtDEvlzDhXU
How was yours, Patrick?
Basic Sponsor
The bearings themselves are relatively cheap at circa $100 but putting them in is time consuming and can get expensive if the large pins do not come out easy.
Rest in Peace
Just a heads up, on those type of wheel bearings they have to be "Clocked" in exactly the right position for the inner races to come off with out damage to the bearing itself.
Just in case any one was thinking of taking them apart and putting grease in them and using them again.
http://www.youtube.com/user/billbmsn.../5/GtDEvlzDhXU
Received 1,223 Likes
No, those pins don't ALWAYS go out that easily!
Ask me how I know!
https://rennlist.com/forums/928-foru...s-are-out.html
Mine needed a 20 tons press and alot of heat after A LOT of work trying everything to remove those fuc...s!
Chronic Tool Dropper
Reminder that some common (or uncommon...) front-drive wheel bearing extraction tools will let you do the job without removing the carrier from the car. I bought and use the Sir Tools setup and it makes rear bearing replacement relatively easy. I have one near Los Angeles (Rob Edwards is holding on to it right now). I think Dean Fuller has one in Mississippi, and Bill Ball was in the process of getting one last spring. The kit was a few $hundred to buy, so look around for a nearby kit. I'm sure there are other folks who have them too.
Okay so now I am paranoid and am gonna have to replace my rear bearings.
I did my right rear last winter due to some sound I could not locate. Turned out the noise was not the rear bearing, but when I pulled it out it looked very similar to what the OP shows. Just replace the bearings with new, but don't be an idiot and forget to put the circlip back in before you press the hub in. I was a dork and did that on my own, in the end it cost me two bearings for that one side.
Rest in Peace
PS, don't ask any of our parts folks about that.
This list is great in making you paranoid and do un-needed repairs on your car.
So who has the tool and willing to lend it to remove and replace the rear bearing near NYC?
Bilal
Bilal
I'm experiencing a right rear noise that we attribute to be the wheel bearing. If yours was not the wheel bearing, can you share what you found out was the culprit?
Thanks in advance.....
LeeRox
It was the front wheel bearing.
The rear one was on its way out, but wasn't making the noise I thought it was.
