928 Forum 1978-1995
Sponsored by: 928 Specialists
Dumb Tire Question: Any reason to match profiles F to R?
Old 12-09-2011, 02:49 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Default Dumb Tire Question: Any reason to match profiles F to R?
If I use a say, 35 profile tire in the rear, is there any reason why I shound/need/have to stay with a 35 up front?
Say:
285/35/18 rear (11" wheel)
245/45/10 front (8" wheel)
Old 12-09-2011, 02:58 PM
928mac
928mac's Avatar
From what I have been told, no
Old 12-09-2011, 03:41 PM
z driver 88t
z driver 88t's Avatar
Always been my understanding that it's best to match the outer diameter as close as you can rather than the profile. For example, the outher diameter of a 245/45 16 on the rear is within 0.3 inches of 225/50 16 on the front. If I were to try a 245/50 16 on the rear it's almost an inch taller.
You can check the specs of most size combinations on Tire Rack's website.
Old 12-09-2011, 05:09 PM
anonymousagain
anonymousagain's Avatar
No.
Especially with wider rears, you'll want a lower profile than the fronts to keep "similar" diameter...but not required. eg, 'Vette's come from the factory with different size, profile and overall diameter.
Old 12-09-2011, 05:13 PM
No HTwo O
No HTwo O's Avatar
My 993 Turbo is 295/30/18 rear and 235/40/18 front. OEM was 285/30/18 and 225/40/18.
Old 12-09-2011, 06:03 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,077 Likes on 1,186 Posts
My commute to work is mostly left hand turns so I actually have taller profile tires on the ride side of my cars.
Old 12-09-2011, 06:04 PM
No HTwo O
No HTwo O's Avatar
How do you get home?
Old 12-09-2011, 06:06 PM
hacker-pschorr
Very carefully.
Old 12-09-2011, 06:09 PM
No HTwo O
No HTwo O's Avatar
^How many shares of Packer stock did you buy this week?
Old 12-09-2011, 06:19 PM
T_MaX
T_MaX's Avatar
I say, go make your day!
Old 12-09-2011, 06:25 PM
jon928se
jon928se's Avatar
Say:
245/45/18 front (8" wheel)
For cars with ABS
1 You need to keep the same (ish) overall diameter both front and rear. Alternatively defined as keeping the sidewall height approx the same (if the rims are the same diameter)
2 You do know that the 35 or 45 means the height of the tyre (sidewall height if you like) is 35% or 45% or the width of the tyre.
35% of 285 = 99.75mm =3.9"
45% of 245 = 110.25mm = 4.33" = too big
a better option would be 245/40
40% of 245 = 98mm = 3.85" near enough to 3.9"
3 In the absence of any other consideration ideally you want to keep the diameter (2x sidewall height + wheel diam) about the same as the original wheels to make the speedo read correctly.
245/40/16 = 24.67" dia = original
285/30/18 = 24.72" dia = orig + 0.21%
245/35/18 = 24.74" dia = orig + 0.29%
245/40/18 = 26.67" dia = orig + 8.1%
PS corrected your typo 245/45/10 would cool on a Mini Cooper (original 1960's mini not BMW version)
Old 12-09-2011, 06:48 PM
Jerry Feather
Jerry Feather's Avatar
In Reverse?
Old 12-10-2011, 03:33 AM
hacker-pschorr
Old 12-10-2011, 05:12 AM
danglerb
danglerb's Avatar
Could be an issue with ABS type stuff, but otherwise in what way do front and rear tires interact, pretty much none I can think of. Right and Left on the rear you have the differential or maybe a solid axle, so same diameter is required.
Old 12-10-2011, 06:55 AM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Originally Posted by jon928se
1 You need to keep the same (ish) diameter both front and rear. Alternatively defined as keeping the sidewall height approx the same....
Not the experience Jwise and I have. We both run 17 inch wheels/tires on the front, 18 inch on the rear. The tires have almost identical OD. I run 255/295 (F/R) for an excellent ride and handling combination.
Quick Reply: Dumb Tire Question: Any reason to match profiles F to R?
