Oil Pan Won't Come Off
928 Collector
I've done this many times ... but on this engine, I just can't get this buggar to budge. I huess Ernie did it right when he sealed the GT pan ... SHEESH!!!
Administrator - "Tyson"
You need to take all the bolts out first.
Archive Gatekeeper
The pan on my '91GT donor motor had been glued on with some black goo of some sort. I tapped on it gently for a while and then got pissed off and got out the 3 pound deadblow hammer, turned the engine upside down and hit up on the underside harder and harder until it finally gave. Felt like I was going to break the pan in half.
If it has the original gasket that s being replaced Id force it off in several locations with a scraper.
Failing that a larger version of...............BFH
Plastic or wooden wedges placed at intervals around the pan and then a tap with a hammer on each one in sequence has worked for me ... used that method on lots of other diff and gearbox covers too. Saves beating the s**t out of things.
