928 Forum 1978-1995
Sponsored by: 928 Specialists
My 1982 928 Project
Old 06-01-2012, 03:34 PM
  #61
whatudrivin
whatudrivin's Avatar
Figured I would give and update.
The car has been put on the back burner for the time being. I have the opportunity to purchase a 2001 Suzuki Marauder 800 with 14k miles for $1800. I'm jumping on this offer as I have been wanting a bike for a while now. And it will give me something to keep me from rushing on the car.
I know I'm about $300-400 away from having all the parts to try to start the car. Now that I'm starting to have some time free up I'm going to start working on cleaning up the car a bit. Funds are tight atm so can't buy too much to help in cleaning so idk how much I can get done but I want to make some progress. I also need to get a good floor jack as the ones I have do not allow me to lift the car onto jack stands w/o using scissor jacks and I really do not like using those. And eve with those I cannot get it up past the lowest setting on the stands. So I need to purchase a good jack before I can get much more work done.
Old 02-25-2013, 04:35 PM
  #62
whatudrivin
After a long hiatus and a decent tax return I have finally purchased some of the last parts I think I need to see if she will live or not. Here is the list of parts ordered today. With spring time right around the corner why not have something to work on?
Lower Radiator Hose
Upper Radiator Hose
Hose - Radiator-Reservoir
Hose Pressure Switch to Reservoir
Coolant Hose Reservoir-Metal Y
Hose from T Stat to Metal Pipe
Engine Heater Valve Hose
Heater Hose Core-Heater Valve Intake
Heater Hose Core-Metal
In Tank Fuel Strainer
Radiator Drain Plug
Thermostat 83C Wahler
Thermostat O ring
Old 02-25-2013, 04:56 PM
  #63
John Speake
John Speake's Avatar
Good luck ! There's a small seal behind the T'stat, did you get that one as well ? Don't see it on your list...
Old 02-25-2013, 04:57 PM
  #64
whatudrivin
Not sure. I'll give Roger a call and see. Thanks for the heads up!
Old 02-26-2013, 03:15 PM
  #65
whatudrivin
So I've been thinking. Since I have the engine drained of all fluids should I go ahead and get everything and do a timing belt/water pump job? I'm just leery of doing this w/o knowing if it will need more in depth work. Something tells me it wont but I just want to be cautious and not spend my money on things that might be more important.
I know the engine will crank over. I have not done a compression test. Should have done that before starting on all of this. Should I put oil in the car and do a compression test then if it turns out good go ahead and do the timing belt, water pump, oil pump seals and the whole works before seeing if she runs?
Old 02-26-2013, 06:38 PM
  #66
soontobered84
soontobered84's Avatar
It's an '82. Even if the TB lets go, nothing would be damaged in your engine. Minimally, you would just have to put the cams back in the correct positions and install the new timing belt.
Now, in the real world, it would happen this way by the PO, but in OUR 928 world, you would want to rebuild your tensioner and probably replace your water pump WYAIT.
But at least you'll know it runs
Old 02-26-2013, 07:24 PM
  #67
whatudrivin
I plan on doing the whole tp/wp no matter what. Pretty much if it runs I'll want to tear it down and do it all. My main concern is the waste of coolant if I was to do this. I don't have a problem doing the labor. Would the car be fine with just some distilled water to see if she will run for like 5 min or so. Once started and maybe driven around the block to make sure the tranny works I would take everything apart for the tb/wp job and the water would be drained.
Oh and I haven't forgotten you either. I'll be down to a meet this spring for sure. Whether in my car or not I don't know.
Old 02-27-2013, 01:57 AM
  #68
soontobered84
Short answer: it'll be just fine with only distilled water for the short haul.
Old 02-27-2013, 02:00 AM
  #69
soontobered84
You oughta just get it running well. Then bring it down for a tech session which could be replacing water pump and timing belt one afternoon. Lots of experience down here for that and there's nothing like watching and helping do your first one.
Old 02-27-2013, 04:14 AM
  #70
RKD in OKC
RKD in OKC's Avatar
Glad to see you back on it!!! Thought we lost ya to the bikers
I'm planning to head south as soon as the doc says I can start getting vertical again.
Old 02-27-2013, 12:10 PM
  #71
whatudrivin
That sounds like a wonderful Idea. If I remember correctly the belt doesn't look that bad. I'll give it a more thorough examination in the coming days and make a decision. But I will definitely be helping. I love wrenching and that's part of the reason I got this car. I'm tired of fixing other peoples cars all the time and not really having anything to show for it. So I wanted a good project. And I think I picked a great, albeit expensive, one.
Hahaha not lost to the bikers. Just no extra money for working on the car. Bike is about payed off and I'll be able to start ordering parts for the car now.
Start getting vertical again? Have surgery or pull something?
Old 02-27-2013, 02:47 PM
  #72
whatudrivin
John, I just spoke with Roger and it looks like that seal is only on 84 and up.
Also went ahead and ordered all the water bridge seals and such since I'm in there already. And working on a quote for all the timing belt stuff.
Old 02-27-2013, 04:34 PM
  #73
John Speake
Ah ! Sorry to have led you astray !
Old 02-27-2013, 04:38 PM
  #74
whatudrivin
That's no problem. I would rather double check and not need one than to not and need it. Also it lead to me ordering a few more seals and such to finish it up. So it worked out for the better!
Old 04-16-2013, 12:15 PM
  #75
whatudrivin
Default Long overdue update
It seems that I don't know how to put the images where I want them in the post so they are all at the end.
Been a while since I have had time to even look at my car. Between doing a head gasket job on my grandmothers Ford Windstar, re-grouting her cabinets, and helping my mother rebuild her kitchen I have had little spare time. I am hoping this will change soon.
Anyways I was able to remove my fuel tank over the weekend and do a bit more inspecting on the car. Here is what I found. Plenty of pictures.
The fuel tank was worse than I thought. You can see the varnish running as I left it on it's end over night. I tried to remove the in-tank filter but it wouldn't budge and I was worried about stripping it. So I poured some sea foam into it and was planning to let it soak, but I forgot to cap the end! Wasted a full bottle on my driveway. Going to get some more items tonight to try and loosen it up. I saw the thread about using a hose clamp to help keep it from spinning. And adding PB blaster to the threads. Any other ideas??
Did some closer inspection of the timing belt and it looks like I will be needing a set of cam gears. These are pretty worn out! Knowing this I am shooting to get her running to make sure everything works and then will tear apart to replace the gears and TB/WP and add a Porkensioner.
I don't have any pictures of this part but the 14-pin connector is not too bad looking. I did see some corrosion on at lease 1 wire but none within the connector itself. It has the plastic covers on them so I believe this helped keep it out. I will look more into it later.
And here are some pictures of the interior. I have been meaning to take these but haven't had the time. I don't know if I have seen a car with this color combo before. I have done some looking but didn't find pictures. I plan on using the same colors when I redo the interior.
Also my rear hatch will not open. Wont open with key and will not open with battery in car. The keys I have will turn in the lock but feel like they are not catching on or are slipping past something. It is a PITA installing the battery from the front doors. Where can I start to get it open again?
All my pictures can be found in my Imgur album here: http://imgur.com/a/m9Kzf
Quick Reply: My 1982 928 Project
