What's with this other type of intake hose?
I was looking at Autoatlanta's IPB, and noticed that they illustrate two different kinds of intake (suction) hoses for 87-91, but they only have information about the one piece one. Anyone know anything about this other type of hose (items 12-15)?
http://www.autoatlanta.com/porsche-p...-91/106-00.php
Archive Gatekeeper
There were 323 cars sold in Saudi Arabia (country code 31) and Arab Gulf States (country code 32). Can't imagine there are too many sets of those tubes lying around.
the down side of those cars is that they never had an oxygen sensor... apparently the fuel back in the 80's and 90's in the ME was really low quality, so an oxygen sensor became obsolete?
I'm busy buying a GTS and there is some weird stuff on there.
I'll post a thread with some pictures as soon as I have the car in my possession SOON!
They probably did have leaded gas because the vehicles there were probably running a super low CR of like 6 or 7:1. Believe it or not, the world average compression ratio of roadgoing cars today is 6.6:1.
These have been referred to a few times before, so I thought it was about time everyone can see exactly what they are, and how they work.
I'm attaching a few pics which are self explanatory, and have also done a diagram, because it's not immediately obvious from the outside how it works, and its made up of a few parts.
From the normal inlet points at the front of the car, the air comes in through an aluminium front tube, which is connected to the sand separator with a rubber sleeve, as you can see in the first pic.
Here's a cross sectional drawing showing internal detail and some dimensions.
When it goes into the front of the separator it firstly runs through a 75mm long vortex generator, which throws any heavier gritty particles to the outside of the tube.
After it exits the vortex generator (a further 75mm), there is an inner tube which creates an annular space which traps the grit, which is swirling around.
At the bottom of that annular space is a small outlet which allows the grit to drop into a non return nozzle, which will allow any grit to drop out when there is no suction after the engine is turned off.
I can't see a part number on mine but, if you can still get them Roger (928'sRus) should be able to track them down.
If you want me to post some more detailed pics here, let me know.
Edit: It wouldn't be difficult to make an alternative replacement part to do the job.
