928 Forum 1978-1995
Sponsored by: 928 Specialists
No power to A/C Head or teminal 86 on HVAC blower relay
Old 06-16-2012, 08:40 AM
mcholdfast
mcholdfast's Avatar
Default No power to A/C Head or teminal 86 on HVAC blower relay
It's an 88 S4. We have no power at all to the A/C control head or the switch panel directly below it in the console. We've had pretty much everything off of this car to either replace or clean so anything is possible.
What is the power source for terminal 86 on the fan blower relay. Wally says it comes from the ignition switch but is there a connection somewhere in between that we may have left loose? Where do we begin?
Old 06-16-2012, 08:44 AM
Dan87951
Dan87951's Avatar
Subscribe! My dad is having a similar problem with his. He said while he was driving the interior temp sensor (right to center vents) was glowing red and a puff smoke came out and everything died. By chance did this happen to you as well? I haven't had a chance to troubleshoot but will be down there today for father's day weekend.
Old 06-16-2012, 10:12 AM
mcholdfast
mcholdfast's Avatar
No, different situation here. This one was working before we took everything apart to replace the dash, clean the CE panel, replace the vacuum pods, etc. etc. etc.
We are getting ready to try a third A/C control head. We had a spare but not sure if it is good so I'm pulling another that's known to be good. Will report back soon.
Old 06-16-2012, 10:30 AM
mcholdfast
mcholdfast's Avatar
Third known good A/C control head made no difference. Still no power. We'll keep searching. Any suggestions appreciated.
Old 06-16-2012, 10:41 PM
mcholdfast
mcholdfast's Avatar
We figured it out about an our or so after the previous post. I'll let this post simmer for a while and see if anyone guesses what the problem was.
Old 06-20-2012, 11:40 AM
mcholdfast
mcholdfast's Avatar
No input so I'll spill the beans.
When you disassemble the dash and console of an 88 S4, be careful. There are two 6 pin wire connectors near the console that can easily be swapped. This will result in no power to the A/C head unit or switch panel below.
Old 06-20-2012, 12:24 PM
fraggle
fraggle's Avatar
Ooo bet I did that one, then ohmed out and tested bloody everything, found no problems but a blown 7A fuse, buttoned it all up and it worked fine.
Quick Reply: No power to A/C Head or teminal 86 on HVAC blower relay
