S4 and Greater Fan Control Module
#121
Yes! Tony - I run these fans on my 1990 S4 in place of the two originals.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
you have that whole shroud/assembly...or just the fans?
#122
e.g. how the controller drives the amplifier.
#123
I used the whole shroud assembly. From memory, I cut mounting tabs off, notched the bottom of housing to attach to radiator and used straps to attach to upper radiator mounts. It is very straightforward and is less deep than the original fans.
Many folks pulled these same fans off a Ford Contour, I think. I just preferred new, at that price. No pics at the moment.
https://rennlist.com/forums/928-foru...ht=dorman+fans
#124
Until you source replacements..for $300-400 amps..controllers...then fan motors. Each his own.
#125
As mentioned before, most don't know how to troubleshoot the cooling system and usually assume it's the power module.
The power module is extremely simple to test, i.e. a ten minute effort worst case. Used/tested modules are available
for less than $150.
#126
First, the controller (silver box) basically never fails. The power module (black with fins) has a failure rate less than 1-2%.
for less than $150.
for less than $150.
#127
Shark2626 (06-23-2020)
#128
Electron Wrangler
for less than $150.
for less than $150.
My own observations of Rennlist traffic on this and personal experience suggest it must be much higher than 1-2% lifetime (so far). I do still think the modules are acceptably reliable given their duty and easily enough repaired that a replacement design is not a high imperative. If a fan stops working it is most likely the fan itself or connectors/wiring at fault.
Alan
#129
Its unbelievable how robust the factory system actually is. Especially when you consider the design of the output stage, and how much current and heat those gates have put up with. I got my scope out the other day to start logging the control signal. I think that maybe just an updated circuit board and a bit simplified layout would be pretty easy project. I already reverse engineered the connector, so I can make those.
I gather its a fairly simplistic duty-cycle style control, but have no idea what the frequency is yet, or how it relays back to the control that "I have a bad fan, run the other on full". I see the wire that does this, but need to watch that behavior to see what its sending back.
#130
and the power module is the easiest to assume as the failure point?
#131
Electron Wrangler
#132
Correct.
It doesn't. The is no processor in the power module, it's "dumb".
#133
Loren,
That is interesting. From reading the manual, and experience, there are failsafe modes that call the fans to run at 100% and also check the fans for non-running conditions. I interpreted that it should check the fan (assuming a current draw) and if it was out of spec, it caused the other fan to run at 100% and waited a period before testing the offending fan again, and then if rectified, it would return to its temperature/conditioned referenced speed.
I made the assumption that this logic was being done inside the controller, as I did not see any comparators or logic devices inside the output stage. However, I suppose it could be done in there with some simple gates. I have not had the time to sit down and draw a schematic from the PCB yet, and have not found one published. If you happen to have one, I would love to take a look.
#134
gate drive voltages for the MOSFETs to saturate them - reducing their power dissipation.
#135
Almost Deleted
