Airconditioner Tracer Dye Clean-Up
What's the best way to clean this stuff up? I've found my leak, or at least the general area it's coming from, but there's so much dye in the area, I can't tell where it's originating from.
It looks like it's spraying out from the expansion valve on the rear evaporator, but before I just replace the "O" rings and clean up, I'd like to be sure it's not anything else.....
Brake cleaner.
Chronic Tool Dropper
Jst don't in hale and you'll be fine, mr. prezident!
Still cleaning...I now can confirm that neither Simple Green nor Evaporator Cleaner (Boomerang) has any noticeable effect without scubbing and wiping down...crap.
Tomorrow, the brake cleaner.......
Also, I read on a thread recently that the "O" rings should be "lubed" before assembly....can't find the thread either....what is supposed to be used?
Rennlist Site Sponsor
I lubricate the O-rings using the same oil that I put in the AC system - mineral for R-12, POE for R-134a retrofits, PAG for a factory R-134a system.
