928 Forum 1978-1995
Sponsored by: 928 Specialists
Shark stranded Road America
Old 08-18-2012, 06:50 PM
tkrtape12
tkrtape12's Avatar
Default Shark stranded Road America
Yep 1st trip ran great now ... Will not start any Help or tips sounds
Like it wants to kick over but won't catch ?
312.919.7001
Pete
Old 08-18-2012, 07:19 PM
James Bailey
James Bailey's Avatar
You need to post more information,like year of the car.
Old 08-18-2012, 07:29 PM
tkrtape12
tkrtape12's Avatar
1987 auto 928s4 103k miles .... New to me a week ago..
Old 08-18-2012, 07:30 PM
tkrtape12
tkrtape12's Avatar
Cranks just will not start... Thanks
Old 08-18-2012, 07:32 PM
James Bailey
You have three relays each of which can cause it not to run. All use the same 53 relay same as your horn relay. Do you have a fuse and relay chart ?
Old 08-18-2012, 07:34 PM
Leon Speed
Leon Speed's Avatar
Pedal to the floor and crank again a few times.
Alternatively, look here: http://www.jdsporsche.com/fault%20find.html
Old 08-18-2012, 07:35 PM
tkrtape12
tkrtape12's Avatar
Yes
Old 08-18-2012, 07:38 PM
James Bailey
borrow the horn relay assuming the horn works and switch it into the Ignition ,Fuel pump location, LH location. If you count from left to right top row it is 8 , 10, 12.
Old 08-18-2012, 07:41 PM
tkrtape12
tkrtape12's Avatar
Trying now
Old 08-18-2012, 07:49 PM
tkrtape12
tkrtape12's Avatar
Just started
Old 08-18-2012, 07:52 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Jim to the rescue
Old 08-18-2012, 07:55 PM
robot808
robot808's Avatar
Jim is a stud.
Old 08-18-2012, 07:58 PM
tkrtape12
tkrtape12's Avatar
Dude owe you a Morton's steak ! Thanks
Pete
Old 08-18-2012, 08:59 PM
James Bailey
Relay, relay, relay.......sometimes even a blind pig finds an acorn.
Old 08-18-2012, 09:55 PM
928 at last
928 at last's Avatar
Default And....
Originally Posted by tkrtape12
Just started
With the relay change where?
Quick Reply: Shark stranded Road America
