928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel lines and fire !!
Old 10-04-2012, 10:03 PM
James Bailey
James Bailey's Avatar
Default Fuel lines and fire !!
Spent some time at Greg Brown's shop getting new chassis to engine fuel lines made. Greg has had all the oddball fittings made to fit the early cars like the old very brown 1980. Photos show the old lines in the car, old line out of the car where they REALLY look bad and the new custom replacements. At the same time replaced the coolant tank and re did some vacuum lines bypassed the heater core.
The sad burn photo is a 1991 GT bit over 100,000 miles and now TOAST !!
So if you wish to avoid such a thing replace those line before. Mine lasted 32 Years but the GT only made it 21 years.
I was only preserving my $2,000 investment and only carry liability insurance .....having trouble compressing the first photos will get them up later...
Old 10-04-2012, 11:58 PM
James Bailey
One more time ...... working on the other photos but you get the point !
Old 10-05-2012, 12:02 AM
JohnnyV
JohnnyV's Avatar
Everytime I see one of these posts, I get chills.. I really have to go over all my lines soon. Thanks for the reminder.
Old 10-05-2012, 12:10 AM
IcemanG17
IcemanG17's Avatar
SCARY...................................I am lucky that the fuel lines on Casper were changed in 2008 when the car was built...............
Old 10-05-2012, 12:11 AM
erwalker
erwalker's Avatar
I replaced all of my injector hoses and anything else rubber under the hood that I could see regarding the fuel line but the ones you show weren't done. Aside from the injector hoses and lines leading to the injector rails, what else needs to be replaced? Are these lines from the tank? Or the CIS? I have an '82 so hoses for the CIS sytem would not apply.
Now I'm nervous that I have missed a 30 year old hose somewhere!
Old 10-05-2012, 12:12 AM
the flyin' scotsman
the flyin' scotsman's Avatar
First thing I did when I bought the GTS and yes I did use Greg Browns fuel lines.......pieces of art
Old 10-05-2012, 12:14 AM
the flyin' scotsman
Originally Posted by erwalker
I replaced all of my injector hoses and anything else rubber under the hood regarding the fuel line but the ones you show weren't done. Aside from the injector hoses and lines leading to the injector rails, what else needs to be replaced? Are these lines from the tank?
The pics are from Jims 80 928........what year is yours as they changed much
Old 10-05-2012, 12:19 AM
James Bailey
Yes these are beside the engine on the early cars feed and return lines. There are variations on the different years. Some hose were rubber, some plastic with different style fittings depending on how the were attached for the factory hoses. Note how the "LOOKED" better on the top side in the car really bad when removed !!
Old 10-05-2012, 12:21 AM
erwalker
erwalker's Avatar
Mine is an '82 - the lines he shows don't look like they are from under the hood on my car but I thought they might be from around the tank/fuel pump/filter area (or for the CIS).
Old 10-05-2012, 12:48 AM
Barry Chan
Barry Chan's Avatar
Is there a reason Porsche installed the fuel lines so close to the motor??
Old 10-05-2012, 04:28 AM
daveo90s4
daveo90s4's Avatar
Yes, more car sales :-)
Old 10-05-2012, 05:01 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Those old hoses had at least another 500 miles in them before you would have been in trouble. Well, maybe only 300.
Old 10-05-2012, 07:59 AM
Leon Speed
Leon Speed's Avatar
What burned in the first picture - looks like the ("non pressure") return line?
Old 10-05-2012, 08:50 AM
erwalker
erwalker's Avatar
Ran out last night to the garage to check (We are getting our first snow storm (minor one at least) of the season) but glad I went and looked! My '82 has the exact same lines that Jim showed in his last photo. Look good on the outside but I don't trust 30 year old rubber. Now on my list to replace before spring.
Thanks for the pics Jim! And I thought I had done my due diligence.
Old 10-05-2012, 08:54 AM
ammonman
ammonman's Avatar
My guess would be the line between the FPR and the rear pressure damper let go and fuel drained down the back of the block and clutch housing onto the exhaust.
Mike
Quick Reply: Fuel lines and fire !!
