928 Forum 1978-1995
Sponsored by: 928 Specialists
Penetrating Oil - interesting
Old 10-15-2012, 08:06 PM
Jim M.
Jim M.'s Avatar
Default Penetrating Oil - interesting
For All of you Mechanic's and Self doer’s out there.
This was in one of the Military Vehicle Club newsletters.
Penetrating Oils
Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then tested the break-out torque required to loosen the nuts. They treated the nuts with a variety of penetrants and measured the torque required to loosen them.
This is what they came up with:
Nothing: 516 lbs
WD-40: 238 lbs;
PB Blaster: 214 lbs;
Liquid Wrench: 127 lbs,
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat out the commercially prepared products costing far more.
Old 10-15-2012, 08:18 PM
Ethre
Ethre's Avatar
Interesting Jim - thanks for the information.
I don't suppose the acetone/ATF mixture is much good for your hands though.
Old 10-15-2012, 08:23 PM
G8RB8
G8RB8's Avatar
Neither is smashing your knuckles into iron. I'll give it a try.
Old 10-15-2012, 08:42 PM
Tom. M
Deleted
Tom. M's Avatar
Wally P has been talking about this for years.... I haven't tried the acetone/atf mix yet, but the kroil we have around the shop works way better than anything else so far...
https://rennlist.com/forums/928-foru...ating-oil.html
Old 10-15-2012, 08:43 PM
Bilal928S4
Bilal928S4's Avatar
Didn't Wally come up with this one a long time ago?
Old 10-15-2012, 08:45 PM
jpNcos
jpNcos's Avatar
I knew PB was better then WD40...
Old 10-15-2012, 08:48 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Which is why PB isnt a Water Dispersent, and WD40 is.
Not the same products..although people will still reach for it...but it does OK.
Old 10-15-2012, 08:51 PM
GlenL
GlenL's Avatar
I like Liquid Wrench in the little squeeze bottle. Goes where you need it and lass dripping. A spray is still useful when the bolt isn't accessible or can't get gravity feed from the bottle.
Old 10-15-2012, 08:54 PM
Speedtoys
Speedtoys's Avatar
Ive always wondered..what it would take to make a tool, where accessible...you could push onto a frozen bolt head, end, or nut...and use sound energy to disassemble the frozen material in the threads.
Like an air hammer, just more for this specifically.
Old 10-15-2012, 09:02 PM
Fogey1
Fogey1's Avatar
Originally Posted by Speedtoys
Ive always wondered..what it would take to make a tool, where accessible...you could push onto a frozen bolt head, end, or nut...and use sound energy to disassemble the frozen material in the threads. ...
Old 10-15-2012, 09:10 PM
Jim Devine
Jim Devine's Avatar
"Ive always wondered..what it would take to make a tool, where accessible...you could push onto a frozen bolt head, end, or nut...and use sound energy to disassemble the frozen material in the threads.
Like an air hammer, just more for this specifically."
I knew a tech that worked at a Jaguar dealership. On the older 6 cyl engines if there was a gasket leak the head stud would corrode to the head. What they would do to get the head off was to take off the nut on the stud & replace it with a junk one barely finger tight & put a blunt tip on the air chisl & rattle it to break the corrosion loose & periodically soak it with penetrating stuff. Sometimes took a while, but
it seemed to work.
Old 10-15-2012, 09:20 PM
Speedtoys
Speedtoys's Avatar
Originally Posted by Fogey1
Good tools cost $.
Old 10-15-2012, 10:06 PM
martinss
martinss's Avatar
What about freezing? I've never tried this but it sounds interesting:
Old 10-15-2012, 10:11 PM
Speedtoys
Speedtoys's Avatar
Hmm..interesting. Shame you have to use 1/2 of a can to do it. *heh*
I could see applying SOME head, then using it to help as well.
Old 10-16-2012, 12:25 AM
snoz
Addict extrordinare
snoz's Avatar
Originally Posted by martinss
What about freezing? I've never tried this but it sounds interesting: http://www.youtube.com/watch?v=b0BaowQvL6c
I tried freeze off on a broken throttle body mount. It didn't work. The mount was broken off below the top of the hole though. It might work better if there was some of the bolt left sticking out.
Quick Reply: Penetrating Oil - interesting
