928 Forum 1978-1995
Sponsored by: 928 Specialists
Digital Torque Wrench - Special
Old 10-16-2012, 06:11 PM
blmw
Former Vendor
blmw's Avatar
Default Digital Torque Wrench - Special
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: Renn
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until November 17th, and is only for the lower 48 states.
Old 10-16-2012, 06:16 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Id hit that.
Old 10-16-2012, 07:30 PM
BC
BC's Avatar
All I need to know is if Greg B suggests this unit, I'll buy it.
Old 10-16-2012, 07:53 PM
UncleMaz
UncleMaz's Avatar
Pending...
Old 10-16-2012, 08:19 PM
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by MJ928
Pending...
Well played Sir.
Old 10-16-2012, 08:20 PM
BC
BC's Avatar
Well there are entire threads on tools where he has been a great resource, so I am excited to find out.
Old 10-16-2012, 08:27 PM
Tom. M
Deleted
Tom. M's Avatar
LOL... I expect Gregs response to be something on the order of
"If you want to torque head bolts on a Devek Stroker or Carl F turbo motor..then it will be fine".....but nothing short of a snap-on will ever touch a GBB Stroker "
LOL
Old 10-16-2012, 10:15 PM
raidonzap
raidonzap's Avatar
Post
I have one and completed my MM job with it, worked very well...recommended!
Old 10-17-2012, 12:28 AM
Lizard928
Lizard928's Avatar
Not for me.
The unit I have does angle (manditory for a 928), and has 2%+/- accuracy.
I doubt Greg Brown would support this unit either.
Old 10-17-2012, 12:33 AM
Speedtoys
Speedtoys's Avatar
It'll work better than my broken cheap one.
Old 10-17-2012, 01:58 AM
EspritS4s
EspritS4s's Avatar
How long is the warranty?
Old 10-17-2012, 08:02 AM
Bilal928S4
Bilal928S4's Avatar
I thought Greg only used REAL tools from 'Harbor Freight'.
Old 10-17-2012, 08:08 AM
17prospective buyer
17prospective buyer's Avatar
Hahahahahahaha!
Old 10-17-2012, 02:17 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I think that you'll find Greg is a purposful tool buyer, and that there won't be H-F tools used for anything important. And for Greg, EVERYTHING is important.
Old 10-17-2012, 02:30 PM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Just ordered one. Price is good, will report on quality later.
As I recently had my Snap-on 1/2" and 3/4" torque wrenches stolen I need replacements. Snap-on is no longer in the near term budget.
Blmw, any other products on the horizon? It would be good to post a video comparing the accuracy of your torque wrench with other common brands.
Quick Reply: Digital Torque Wrench - Special
