928 Forum 1978-1995
Sponsored by: 928 Specialists
Ground strap.... stock or make one?
Old 11-08-2012, 10:13 PM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by Arnoud
+1, and as I wrote in my very first introduction post "...Alan Moore: for all things electric/electronic, and I have - shamelessly - implemented several improvement project items as documented on his web-site."
When I made mine, I used 3mm thick aluminum with the following profile (turned out not to be 100% perfect, as I could only fit the battery switch within the space in a slightly tilted position - rather then fully straight):
Yes that looks familiar! I can see yours is taller than mine - the bend can be closer to the switch... But then the bolt is very awkward to get in - still it rarely will come out.
BTW at waytek you can buy spare keys and plastic covers - so if you cut down the key flush (with a screwdriver slot cut in) as I did you can cover the whole thing up.
Alan
Old 11-09-2012, 09:28 AM
harborman
harborman's Avatar
Originally Posted by harborman
Get the one from 928 Intl for $30. Just got one today!
PS. I was able to open up the crimped end, pull out the braid, use a Dremmel tool to clean the inside and brain, then stick it back in and recrimp in a vise. Worked until I replace with a new one.
Mine was full of corrosion.
Yes, mine was too, but I was able to clean it up and reuse.
Old 11-09-2012, 10:23 AM
longleader
longleader's Avatar
I just ordered a few from Waytek this morning; I only need 1 but didn’t want to pay the “$5.00” handling fee for orders under $35.00 so I got 3.
Old 11-09-2012, 10:29 AM
Ducman82
Ducman82's Avatar
i cant wait for mine to get here. found a local shop with a nice group 48 AGM battery
Old 11-09-2012, 11:07 AM
dprantl
dprantl's Avatar
Originally Posted by Alan
I also have dual small braided ground straps for the block to chassis grounds - also from Waytek.
I was looking for this on Waytek's site, but no luck. Do you by chance remember the part number or description of that strap?
Dan
'91 928GT S/C 475hp/460lb.ft
Old 11-09-2012, 11:47 AM
Alan
Electron Wrangler
Alan's Avatar
Dan
Dan - I looked - it appears they don't do them any more...
Alan
Old 11-09-2012, 02:40 PM
Jim Devine
Jim Devine's Avatar
Even cheaper than Waytek! - $ 8.00! At this price it probably should be an automatic change out. Might fix a lot of phantom electrical problems. If nothing else,
it's new & you can clean the positive terminal too while you're there.
http://brillman.com/store/16-ground-strap.html
Old 11-09-2012, 03:00 PM
Ducman82
Ducman82's Avatar
i just picked up that group 48 and the 16" strap seems a bit short...........
Old 11-09-2012, 03:08 PM
longleader
longleader's Avatar
Alan
http://www.waytekwire.com/item/36282/
Old 11-09-2012, 04:38 PM
depami
depami's Avatar
Dan
Alan
Originally Posted by longleader
I think they meant Waytek no longer shows these.
http://www.mcmaster.com/#grounding-straps/=k3cb39
Old 11-09-2012, 04:45 PM
stolarzj
stolarzj's Avatar
24" and 2awg http://www.grainger.com/Grainger/GRO...-Braided-2FFT2
Old 11-09-2012, 05:14 PM
Alan
Electron Wrangler
Alan's Avatar
Yes what Dan was asking about were the short 2AWG braided straps made up with flat 5/16 terminals crimped on on each end.
Alan
Old 11-09-2012, 07:57 PM
Ducman82
Ducman82's Avatar
Stock 16" strap is a little short with a group 48......
Old 11-09-2012, 09:22 PM
Jim Devine
Jim Devine's Avatar
I'm not sure, but don't the pre '86 cars take a battery that is longer? It looks like you have a lot more room behind your battery then my 86.5 with a group 48. Someone here would know more about it.
Anyway, Problem solved- $ 8.75-
Brillman has some 19" ones which would be too long, but you could adjust the length by making
a "U" in it just behind the battery- wouldn't take much.
http://brillman.com/store/19-ground-strap.html
Old 11-10-2012, 01:03 AM
Ducman82
Ducman82's Avatar
thats what im guessing. thats a HUGE battery hole. i never had a hold down either. that group 49 was going nowhere.... this little guy though......
Hummmmm
Quick Reply: Ground strap.... stock or make one?
