928 Forum 1978-1995
Sponsored by: 928 Specialists
Aux Air Valve Question
Old 03-03-2013, 12:19 AM
LT Texan
LT Texan's Avatar
My idle just went crazy - about 2k rpms when fully warmed up.
I couldn't slow it down with the idle adj screw.
I pulled the Aux Air Valve,
It was hot. Had to hold it with a towel.
And it was not fully closed.
Does that make sense.
(always something!)
Old 03-03-2013, 11:54 AM
Dennis Wilson
Dennis Wilson's Avatar
LT,
It sounds like the heater winding has fried and is shorting to the body of the AAV. You can check it by testing for a circuit from the positive connector to the body of the AAV.
Dennis
Old 03-03-2013, 01:33 PM
Luis_M
Luis_M's Avatar
2k seems too high to be due to the aav, even wide open. Pinchthe hose leading to the AAV and see how much it slows down. I think you must have a large vacuum leak somewhere else...
Old 03-03-2013, 03:29 PM
Ducman82
Ducman82's Avatar
my 3 wire at full open does 1200.....
Old 03-03-2013, 05:16 PM
LT Texan
LT Texan's Avatar
I removed the AAV, hooked it up to power at the jump post, it was fully closed in 6 minutes.
So I bet I got the wiring loom plugs mixed up.
Off to the garage with the current flow document and my multimeter.
Old 03-03-2013, 07:00 PM
LT Texan
LT Texan's Avatar
Bad ground connection in the AAV plug and wire loom ground point! All is well now.
Quick Reply: Aux Air Valve Question
