928 Forum 1978-1995
Sponsored by: 928 Specialists
Ok, i am stumped .. trans fluid help
Old 03-07-2013, 04:51 PM
  #61
G8RB8
G8RB8's Avatar
So what's this?
Old 03-07-2013, 05:06 PM
  #62
Leon Speed
Leon Speed's Avatar
Looks like a socket for the diff plug(s).
Old 03-07-2013, 05:08 PM
  #63
whatudrivin
whatudrivin's Avatar
You mean an extension for a wrench?? No place for a ratchet to connect.
Old 03-07-2013, 05:17 PM
  #64
Leon Speed
Leon Speed's Avatar
On the bottom
Old 03-07-2013, 05:19 PM
  #65
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,540 Likes on 1,228 Posts
Yes, but only from '78 to '85 or '86 (not sure which).
Old 03-07-2013, 05:23 PM
  #66
G8RB8
G8RB8's Avatar
If you follow the link. http://www.autoatlanta.com/Porsche-T...N-RTL1033.html It states you cannot change the fluid without it.
Old 03-07-2013, 05:25 PM
  #67
whatudrivin
Originally Posted by Leon Speed
On the bottom
oooooo.... I was thinking upside down. I could see it now. How big is that hex?
Old 03-07-2013, 09:49 PM
  #68
Hilton
Hilton's Avatar
17mm on the early cars' diff drain plugs.
The later size is 10mm hex.
Old 03-10-2013, 05:59 PM
  #69
NoVector
NoVector's Avatar
Thanks Arnoud!
Old 03-10-2013, 06:27 PM
  #70
depami
depami's Avatar
^^^^^ How is that transmission so clean?
Old 03-10-2013, 07:54 PM
  #71
Rob Edwards
Archive Gatekeeper
'Cause he cleaned it?
Old 03-11-2013, 01:20 PM
  #72
Arnoud
Arnoud's Avatar
Originally Posted by NoVector
Thanks Arnoud!
Well: thank YOU Bruce, for having taken it immediately into use and posting the pictures here for all to see - great!
Old 03-15-2013, 12:32 PM
  #73
StratfordShark
StratfordShark's Avatar
Great info in this thread - I had no idea about that fill port and it will make AT oil change so much easier.
I ordered a DN 7.2 coupler from a firm in Germany (ESSKA Machines in Hamburg - wish I'd known when I was over in the city last week!). I just ordered one with a female threaded end for the hose barb - though the quick couple end is different from the dimensions used in UK, the threads use the "British Standard Pipe" or BSP fitting, so I could use whichever size is suitable for the hose and the threaded barbs are easily found here.
I'm doing it this way as it is nice to do it "properly", but couldn't you simply clamp a hose of the correct size to the male quick couple connector under that cover?
Old 03-15-2013, 01:39 PM
  #74
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Whiskey Tango Foxtrot...
I wish this thread came out in 2001 when my family bought the car. I have been adding fluid to that reservoir and getting burned because of the muffler while the car is running. Now I hear about this?!
Old 03-17-2013, 07:05 AM
  #75
Arnoud
Arnoud's Avatar
StratfordShark: is it this one you ordered (as it looks like a real good quality and very cheap price if it is) http://www.esska.de/cgi-bin/esska_de...759201,2705xxx ?
And yes: I guess it would be possible to clamp a hose of the correct size to the male quick couple connector, however it might still spill I think given the shape of that connector. For a few $/£/€ and doing it the proper way: no spilling at all.
Andy, look it from the positive point of view: no reason to getting burned anymore !
Quick Reply: Ok, i am stumped .. trans fluid help
