928 Forum 1978-1995
Sponsored by: 928 Specialists
'88 5-speed dyno log
Old 03-14-2013, 04:55 PM
  #61
jbrob007
jbrob007's Avatar
Originally Posted by BC
Have we already gone over why that is true?
I'd like to ask that question again. Why cant the S3 breathe at high rpm? I know if Ken could make the S3 breathe better he would have already, with the exception of the torque rings (which I have installed). Just curious as to what or where the restriction is...?
Old 03-14-2013, 05:30 PM
  #62
Tom. M
Deleted
Tom. M's Avatar
Relative sizes of intake valves (S4 vs S3)..
any questions?
Old 03-14-2013, 06:00 PM
  #63
John Speake
John Speake's Avatar
Yes, they do run at high duty cycles, in the 90's at max power. In the 928 they are run at higher than rated fuel pressure for their 19# rating, so in fact they are behaving more like 24#.
It's debatable whether it is a problem in practice to run near "on all the time" with the power levels likely to be achieved from S4/GT/GTS in stock trim. And that's the market Ken's chips are aimed at.
Porsche didn't give much power away at the top end, they didn't need the huge ignition safety margin they had to use on the S2/S3 which have no knock control system. There are however very useful gains to be made in the mid range on the S4 and later.
Originally Posted by GregBBRD
Has anyone else seen 19 lb injectors at 90% duty cycle on a stock S-4 engine?
John Speake?
I've run 19 lb. injectors in a stroker, before, and made 330 RWHP. I did this with Shawn Smith's engine, during my R&D stage.
That's what is so confusing about what Ken is saying.
Old 03-14-2013, 06:39 PM
  #64
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,458 Likes on 1,460 Posts
any questions?
Tom:
I believe that's a picture of an intake and an exhaust from an S4, not an S3 intake and an S4 intake. The difference isn't that severe.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 03-14-2013, 06:41 PM
  #65
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
And yet they ran the same injectors and fuel regulator in a GTS, making significantly more power....
With the additional power, they must be running near 100%?
Old 03-14-2013, 06:58 PM
  #66
Tom. M
Deleted
Tom. M's Avatar
Tom:
Actually, they are mustang intake valves.... (and it was in jest) but sometimes you need to hit the S3 owners straight up to get the point across LOL
Old 03-14-2013, 07:19 PM
  #67
John Speake
Yes, they are pretty much at 100%. Some of that % will be taken up with the over-rich mixture that Porsche always puts in there as a safety margin for aged MAFs etc.
Old 03-14-2013, 09:19 PM
  #68
PorKen
Inventor
PorKen's Avatar
Even with HIR turned on, I'm hitting 90% duty at 6300 RPM/12.5 AFR, with 24# injectors.
Half Injection Rate only knocks off a few percent duty cycle.
When HIR kicks in, (over 5100 RPM stock) the injectors are firing only once per rev, but the injectors are staying open longer to compensate.
Unfortunately, miscalculations are amplified by HIR, so it can get some really high spikes of rich/lean.
Porsche did about as good as they could with the stock maps.
There isn't a great deal more to get with the available 16x16 maps, the way they are arranged.
Old 03-14-2013, 09:26 PM
  #69
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
That would explain why they do so well by simply increasing the fuel pressure....
Old 03-14-2013, 11:28 PM
  #70
Hilton
Hilton's Avatar
Sounds like you should (also) buy some of the plastic design III 30lb injectors?
Last edited by Hilton; 03-15-2013 at 01:20 AM. Reason: remove ebay link and part numbers to non-24lb injectors to avoid confusion
Old 03-14-2013, 11:35 PM
  #71
MjRocket
MjRocket's Avatar
Originally Posted by Hilton
Sounds like you should (also) buy some of these
http://www.ebay.com/itm/32LB-hr-336-...2424dc&vxp=mtr
They're Bosch 0 280 155 759 32lb 4-hole design III with the correct grooves for stock injector retainers.
Can anyone confirm that these are the ones we want and will fit? That's a good price IMO if so
Old 03-14-2013, 11:52 PM
  #72
PorKen
Inventor
PorKen's Avatar
Someone was telling me the plastic 30 lb were easier to find with the grooves than the 24 lb...
Old 03-14-2013, 11:56 PM
  #73
MjRocket
MjRocket's Avatar
Hey PorKen would these 32# be the right fit and Optimal injectors??
Old 03-15-2013, 12:00 AM
  #74
PorKen
Inventor
PorKen's Avatar
Fit, yes.
I probably wouldn't go that big unless you put some decent cams in, and are SharkTuning.
24 lb is borderline for stock w/X-pipe, but it's close enough that I'm not swayed to move to 30's, yet.
It's more and more difficult to keep HCs reasonable at low (test range) rpms, the bigger you go.
Or maybe better said, the bigger I go.
I pretty much reverse the MAF scaling so there is little resolution down low, in order to have many more rows at max output (~320 rwhp max only).
Old 03-15-2013, 12:04 AM
  #75
MjRocket
MjRocket's Avatar
Do you by chance have a link to the actual injectors you would recommend?
Quick Reply: '88 5-speed dyno log
