928 Forum 1978-1995
Sponsored by: 928 Specialists
Catastrophic 16v failures solved
Old 02-19-2013, 03:38 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
What is a precombuation chamber?
Tom. M
Deleted
Tom. M's Avatar
We here in the PacNW get lots of moisture as you can imagine...even an engine stored inside but in an unheated space will have condensation build up ...could have built up inside the bores..corroding the valves..
Old 02-19-2013, 03:50 PM
tveltman
tveltman's Avatar
The little chamber that the fuel gets injected into to initiate the ignition. It provides a more complete and even burn:
Diesel Indirect Injection from Wikipedia
Old 02-19-2013, 04:17 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Ok but that's for diesels not gasoline engines.
Old 02-19-2013, 04:43 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Old 02-19-2013, 05:53 PM
jpitman2
jpitman2's Avatar
Condensation or leaked water into an inlet duct could sit on a closed valve, and rust it onto the seat, and first opening of that valve....
Were both bad seats on inlets? Check the back of the valve and the seats for corrosion, but it may have been hammered right out.
My car sat for a while, but I think much less than these cases, and in the centre of Saudi Arabia, and its pretty quiet running still.
Edit: - yes, both inlets , looking at the size relative to the OK valve.
jp 83 Euro S AT 55k
Old 02-19-2013, 07:04 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
What is an OK valve??
Old 02-19-2013, 07:13 PM
jpitman2
jpitman2's Avatar
The OTHER visible valve that seems to be correctly seated - looks 'OK' . Is that clearer?
jp 83 Euro S AT 55k
Old 02-19-2013, 08:09 PM
atb
atb's Avatar
Originally Posted by S4ordie
Seems way too coincidental. Did you find anything in the cylinders or the pans to suggest a foreign object?
My, at present, pessimistic mind thinks sabotage.
Originally Posted by Kiln_Red
It's kind of hard to imagine any other possibility. Two failures exactly alike? Even one engine failing this way is insane. But two?
Middleton!
Old 02-19-2013, 08:16 PM
supercedar
supercedar's Avatar
There is a lot of sodium in that there part of town. It will be in the air,water and your lungs. I know for a fact that wood pellets that are manufactured down there on the waterfront are known to eat pellet stove burn pots up.
Thomas
Old 02-19-2013, 08:52 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,464 Likes on 1,461 Posts
Thomas
Tough to imagine enough rust forming that would rust a valve to a valve seat enough to have the valve pull the seat out of the head....and still have the pistons move in the bores.
I think this is all about heat, but some pictures of the head gaskets and that port with the valve removed might tell more.
That one "fire ring" area on the cylinder head that dropped the valve seat is getting pretty darn thin, from coolant attacking that surface.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 02-19-2013, 08:54 PM
Speedtoys
Speedtoys's Avatar
Better than not ok.
I asked that out loud, that's what my kid said...so...
Old 02-19-2013, 10:37 PM
atb
atb's Avatar
Hey, aren't our valves stainless steel?
Old 02-19-2013, 11:10 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Not good enough, for the Germans.
Those original valves are pretty high tech.
Note that the exhaust valves are two pieces and the heads are not magnetic....and it isn't stainless.
Old 02-19-2013, 11:15 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,575 Likes on 1,242 Posts
Not sure about stainless, but one part of the valve is magnetic and one is not, the stem is friction welded to the fluted part. No idea what alloys they _really_ are.
Quick Reply: Catastrophic 16v failures solved
