928 Forum 1978-1995
Sponsored by: 928 Specialists
PKT warning light?
Old 05-06-2013, 10:31 PM
PorKen
Inventor
PorKen's Avatar
Default PKT warning light?
Possible solution?
Isolate the Tensioner/Damper and attach the warning light wire to it.
This would break ground with both over and under extension.
I reckon it could be about as reliable as the factory 'sensor'.
The arm conducts to the bracket and the pulley.
The piston conducts to the T/D housing at all extensions.
There is a small amount of travel past max extension (pic below).
The warning light will trigger with an intermittent break, IE. it will stay on even if ground is restored.
Should make a small L-bracket to hold the fancy cover connector outside of the cover and plug the cover.
What's required
Heat shrink tubing on the T/D bolts.
Thin Mylar washers on both sides of the T/D bolt holes.
Wire to the factory connector with 5/16" (8mm) terminal at T/D.
Requires drilling T/D holes slightly larger, ~7mm (current holes are a cone shape, 8->6mm).
Old 05-07-2013, 05:35 AM
John Speake
John Speake's Avatar
How does it break the ground connection at miniumum extension ?
Old 05-07-2013, 10:39 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
How is the ground going to break at full extension? What about when it starts streching when a WP is siezed?
Old 05-07-2013, 11:00 AM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I believe over extension can be detected with the use of a small dowel in the hole where the pin is located. If a small pin can be fabbed up, then inserted into the hole once the pin is pulled, all that would be needed is a metal stop of some sorts to trigger the ground and light.
Old 05-07-2013, 11:18 AM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Trying to mimic the OEM system might be folly. Couldn't we measure the distance between the two holes in real-time as an indication of belt stretch?
Old 05-07-2013, 11:33 AM
69gaugeman
69gaugeman's Avatar
I am not sure that would work, as the tendency is to pull the roller onto the pin. By the time that roller is off the pin it would be way too late.
Old 05-07-2013, 12:21 PM
polecat702
Vegas, Baby!
polecat702's Avatar
I've been running Gates HTD belts on my Harley's for over 40 years. Other than the width, or the length, the belts are exactly the same. They don't stretch! Detergent oil will cause the fibers to break down, and shred the teeth. Plus there's a lot more torque on a primary, or final drive belt on a Harley, and we don't use tensioners. The primary drive belt has an idler pulley, but it's only snugged up to the belt. Final drives belts must be able to swing up, and down as the swing arm moves with the suspension, but the belt geometry remains the same, as does the tension. The belts and pulleys last the life of the power train.
Ken's tensioner works! We no longer need the warning light.
I'm running one of Ed's Guardian water pumps, in the Vegas heat, and zero problems.
Old 05-07-2013, 01:06 PM
PorKen
Inventor
PorKen's Avatar
If the T/D is not damping or the piston is not extending then the the belt will flutter/flap (like the stock system).
Movement of the belt will be telegraphed through the pulley and lever.
The piston spring is quite strong. Normally, the piston is firmly held against the lever.
It would take just one break of the piston to lever contact to trigger a warning.
As shown in the pic above, the lever and pulley have a small amount of travel (<1 mm from the piston tip) before the pulley pin hits the stop built into the bracket.
At full extension, the belt will be undamped, so the lever should occasionally lift off of the piston.
It's not a great way of checking for overextension, but this is a much more rare event.
Old 05-07-2013, 01:33 PM
dfrhodes
dfrhodes's Avatar
I'd be happy if the sensor circuit was hooked up to a miles or engine runtime tracker. That way i'd know it was time to change the belt/piston
Old 05-07-2013, 02:02 PM
Randy V
Randy V's Avatar
The piston requires replacement?
First I've heard that.
How does one know when that is required?
Old 05-07-2013, 02:10 PM
Kevin in Atlanta
Wasn't that a feature in the early 928's O2 sensor? Of course you could right down the mileage when you installed it. :-)
Old 05-07-2013, 06:12 PM
dfrhodes
dfrhodes's Avatar
I will defer to Porken of course -
https://rennlist.com/forums/928-foru...-question.html
Old 05-07-2013, 07:45 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
All this setup shows is that the tensioner reached the max limit. Even then, it has to wait until the belt starts to vibrate. This is hardly as good as the factory warning system.
Old 11-22-2013, 03:19 PM
davek9
davek9's Avatar
Hi Ken I think your mod is a viable solution and should give us "PKTensioners" some indication if the dynamic Audi tensioner is not holding constant pressure.
With that being said I do believe that with any critical system as our T Belts, a routine maintenance inspection is unavoidable. With or w/out an idiot light
Ken do you think that the Mylar washers may cause the T/D bolts not to hold torque?
Keep up the good work !
Thanks,
Dave K
Old 11-24-2013, 12:46 AM
PorKen
Inventor
PorKen's Avatar
I considered using studs and a locking nut because of the washers, but I will probably just use red Locktite.
I haven't looked yet at how to connect the wire. I'd like to avoid going under the TB cover so there's no chance of it getting under the belt, somehow.
Quick Reply: PKT warning light?
