928 Forum 1978-1995
Sponsored by: 928 Specialists
FS 1985 928S, x-pipe, new paint, clean in and out.
Old 08-13-2013, 09:25 PM
Adamant1971
Adamant1971's Avatar
Default FS 1985 928S, x-pipe, new paint, clean in and out. UPDATED PICTURES
Some of you may know that picked up an s4 5 spd. So my old baby must go to make room.
I'm the second owner, well maintained. Light accident last year, stripped and re-painted.
Car could use an oil pan gasket chang and will need two new tires for sure. Has the S4 wheels from the 87 on it.
11k takes it away.
110 k miles (175k km's)
Drove her down to SITM this year with no issues.
I purchased the car from a dealer in the city after it was traded in by the original owners wife after he passed away. The car has always been garage kept and never winter driven. Since I have owned it doesn't even see rain. And it's a Canadian car, not an import
Service History During My Ownership
September 2011:
-Replaced water pump with new Laso plastic impeller pump
-Replaced timing belt with new gates belt
-Replaced timing belt guide pulley
-Upgraded factory hydraulic belt tension system to PorTensioner
-Replaced all fuel lines with 928’s r us kit
-New block coolant drain bolts and seals
-New radiator drain plug o-ring
-Replaced cam shaft end seals with new cam cap arm
-Replaced all fluids
-Replaced hood struts
February 2012:
-Replaced TPS harness
-Replaced one power window switch
-Replaced sunroof switch
-Removed cats and installed motorsports x-pipe
-Installed new oem bosh o2 sensor
-Installed Alpine bluetooth/iPod head unit with alpine booster in factory amp location
-Installed 6 Alpine speakers and repaired/replaced speaker rings
April 2012:
-Complete strip and re-paint (same colour)
-New sunroof seal
-New bumper beading front and rear
-New driver and passenger window corner trim
-Deleted rub strips during re-paint, all holes properly welded
-Installed Rob Budd hood liner with graphic
-Removed stealth 80’s radar detector that was found under fender and all wiring
-Installed P-klamp and checked crank shaft end play
May 2012:
-Replaced both front rotors, Zimmerman
-Replaced front brake pads, Hawk HPS
-Installed rebuilt steering rack
-New inner and outer tie rods
-Replaced all power steering lines
-Replaced power steering reservoir and filter
-4 wheel alignment
-Checked tension on flex plate and re-torqued P-Klamp
June 2012:
-Rebuilt door cards and re-assembled
-Replaced sunroof motor cover
-Windows tinted
July 2012:
-Replaced heater control valve
-Replaced all collant hoses
-Replaced passenger seat switch
-Replaced right front crank case breather hose
-Replaced oil filler neck gasket with 16valve version
-Replaced water bridge o-rings
-New oem windshield installed (no antenna)
April 2013
-Replaced spark plugs with oem WR7DC
-Replaced spark plug wires and added heat sheilding
-Installed 1987 S4 fuel pressure regulator
-Installed Porken S300 chips
-Installed Porken TQ rings
May 2013:
-Replaced sunroof drip tray and had sunroof re-painted after I scratched it
-AC re-charged with r134 and leak tested
-Installed jager kit to fix loose centre console
-Removed aftermarket alarm and all wiring
-Checked and re-tighted all fuel lines and coolant hoses
-Replaced all exterior bulbs with correct Porsche bulbs
July 2013:
-Both front calipers re-built
August 2013
-replaced the odometer gear that broke coming back from SITM
-cleaned all contacts, all gauges functioning perfectly
Adamant1971 is offline
Old 08-13-2013, 09:27 PM
Adamant1971
Default UPDATE, MORE PICS
Sorry I will edit text when I get back to a computer.
May be easier to read in my evilBay auction, more photos there as well.
Old 08-13-2013, 10:34 PM
Hollisterkiid92
Hollisterkiid92's Avatar
Looks exactly like mine with burgundy interior:-)
Hollisterkiid92 is offline
Old 08-13-2013, 11:09 PM
Adamant1971
MORE PICS ADDED
Old 08-13-2013, 11:21 PM
jej3
jej3's Avatar
Might want to include a price unless I missed it.
jej3 is offline
Old 08-14-2013, 12:09 AM
BIMMERMIKE
BIMMERMIKE's Avatar
Amazing looking car and runs well. All maintenance is up to date and more.
Nice car Adam!
BIMMERMIKE is offline
Old 08-14-2013, 01:08 PM
Avar928
Avar928's Avatar
Beautiful car.
How'd you get the wheels to look like that? Painted?
Avar928 is offline
Old 08-14-2013, 01:13 PM
Adamant1971
As far as I know they are the original finish. The S4 that I purchased is as original as you can get, the wheels are from the S4.
My speed lines are staying with me for now.
Old 08-15-2013, 12:34 AM
Adamant1971
Pics of the re-paint
Old 08-15-2013, 09:51 AM
davek9
davek9's Avatar
That's a very nice car for that price, you put a lot into it.
Wishing you good luck w/ the sale.
davek9 is offline
Old 08-15-2013, 11:36 AM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,216 Likes on 470 Posts
Very nice car.
GLWTS Adam.
Bertrand Daoust is offline
Old 08-15-2013, 02:06 PM
Barry Chan
Barry Chan's Avatar
Nice car and a lot of work done to it.....That's why there's no asking price!
Barry Chan is offline
Old 08-15-2013, 02:54 PM
BRB-83-911SC
BRB-83-911SC's Avatar
Originally Posted by Adamant1971
13k obo
Post #1
BRB-83-911SC is offline
Old 08-15-2013, 03:18 PM
SeanR
SeanR's Avatar
Great looking car, good luck with the sale.
SeanR is offline
Old 08-15-2013, 04:22 PM
Barry Chan
Barry Chan's Avatar
13k, very reasonable, hope you get it
Quick Reply: FS 1985 928S, x-pipe, new paint, clean in and out.
