928 Forum 1978-1995
Sponsored by: 928 Specialists
Gas Vent System
Old 07-07-2008, 10:26 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,076 Likes on 1,185 Posts
Originally Posted by Mrmerlin
Also to consider is that if the car were to roll over then raw fuel would be spilled out of the filter that you have installed, as its connected to the top of the vent system on the fuel tank, and this could be a fire hazard as well.
This was my #1 concern with doing this modification, so I retained the factory installed check valve before the filter. Car goes *** over tea kettle, valve closes.
Old 07-07-2008, 10:45 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,278 Likes on 1,263 Posts
Hacker where is the check valve?? I didnt see one when I installed the new/used tank. The tank I installed had a 1 inch line that went from the top of the main body and then connected to the top of the tank inlet at a T fitting then the smaller vent went line went to the G fitting on the tank inside the RR fenderwell.
Unless your talking about the Check valve that is in the front portion of the RR fender behind the block off plate. Either way I think gas fumes will still be able to vent and thus cause a fire hazard in an enclosed area
Old 07-07-2008, 12:52 PM
PorKen
Inventor
PorKen's Avatar
But the tipover valve is really heavy! (Essentially a large ball bearing.)
The valve is in the passenger side rear fender, ahead of the wheel, where the second CIS fuel pump would be.
Euros up to MY?? don't have a carbon cannister, and are plumbed from the separator tank through the tipover valve to a steel line which exits behind the bumper.
I sold my '81 to a fellow that immediately parted it out. (thread)
Old 07-07-2008, 02:18 PM
hacker-pschorr
Porken got it
I found my vent system clogged a while back. I didn't see the point in trying to fix it so I took Porken's route and removed everything.
Old 02-22-2022, 12:03 PM
LargeFarva
LargeFarva's Avatar
I went chasing the petroleum cabin stink today and found that not only was my 'Y' connector broken, but that the PO had snipped off the hose going to the valve + throttle body setup. My car is an LS swapped '90 so there was no reason to keep any of that, but reading this thread makes me realize that I need something to put on the end of the hose coming from the gas tank as well as install active air exchange for my garage. Really freaked out by the idea of my crawl space filling up with gas fumes. Many thanks all, 14 years later! (no emissions testing where I live, this could have gone undiscovered for quite some time)
Old 02-22-2022, 01:06 PM
heinrich
928 Collector
heinrich's Avatar
BEWARE: If this is not carefully considered, it WILL suck your gas tank into a little ball and cause a fire.
Old 02-22-2022, 01:22 PM
LargeFarva
LargeFarva's Avatar
I wasn't planning on closing the loop, rather using the open ended fuel filter method described above to provide gas exchange while keeping out particulate. Basically the same as it is now with the broken lines, only with a filter
Quick Reply: Gas Vent System
