928 Forum 1978-1995
Sponsored by: 928 Specialists
Electrical magic Deoxit, yes it`s true, it works !
Old 03-27-2014, 05:44 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,254 Likes on 1,247 Posts
Default Electrical magic Deoxit, yes it`s true, it works !
Well i must confess, I finally spent the cash for a small bottle 25ml of the red Deoxit with the needle applicator.
I had been fighting with my window switches in the Euro for a few weeks and was going to replace them, the sunroof especially wasnt working.
Took the motor apart it looked brand new inside, anyway after spending more time with these switches I figured I would give this stuff a try,
as the next step was a new set of switches.
I took them apart again and cleaned the contacts again and added a very small coat of this red liquid to all of the connector areas, Put them back together add a small amount to the individual female connectors and plugged them back in.
I am sold,
first push the window will slice your arm off it moved so fast....
going to attack the CE panel next even though things seem to be working as they should
Amazon.com: CAIG DeOxIT Liquid 25mL with Needle Applicator: Electronics Amazon.com: CAIG DeOxIT Liquid 25mL with Needle Applicator: Electronics
Old 03-27-2014, 05:47 PM
Chalkboss
Chalkboss's Avatar
Glad it worked for you. I have used it to get a non-op seat switch operational. Just a quick spray. Since then I am using it on any electrical connection that is suspect (many!!!).
Well worth the price.
Old 03-27-2014, 05:49 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,207 Likes on 467 Posts
Thanks for sharing.
Never use it but might in the future.
Old 03-27-2014, 08:21 PM
Dave928S
Dave928S's Avatar
100% agree Stan ... I've used it for quite a while, and use it as a preventative for oxidation on all connections.
A good example was the 12 pin plug which connects my trailer lights to the plug on my road 4WD. Every time I connected my trailer the lights wouldn't work, and I'd waste a heap of time cleaning pins (and swearing) for a result lucky to last until the next use ... sprayed both plugs with deoxit and instantly worked. Everything else I tried before that was useless.
I bought it off the shelf at an electronics store.
Old 03-27-2014, 08:35 PM
Hold On
Hold On's Avatar
Hmmmmm wonder if this would work on my cruise control box and that 12pin plug attached to it ??
Old 03-27-2014, 08:56 PM
wpgshark
wpgshark's Avatar
After you get them clean I've found this stuff further improves the contact and helps keep it in contact.
http://www.amazon.com/MG-Chemicals-Carbon-Conductive-Grease/dp/B005T8ROWA/ref=sr_sp-atf_title_1_1?s=industrial&ie=UTF8&qid=1395964336&sr=1-1&keywords=electrically+conductive+grease http://www.amazon.com/MG-Chemicals-Carbon-Conductive-Grease/dp/B005T8ROWA/ref=sr_sp-atf_title_1_1?s=industrial&ie=UTF8&qid=1395964336&sr=1-1&keywords=electrically+conductive+grease
Lance
I have a winch on the excursion the ground is run through the chassis to the back, I have back and front receivers so I can move it around, anyway the contact on the back was always giving trouble regardless of how clean I got it, put this in and it's been a none issue for 2 winters, I'll probably take a look this summer.
Old 03-27-2014, 09:16 PM
yardpro
yardpro's Avatar
i love the stuff... but boy it is pricey
Old 03-27-2014, 11:44 PM
MGW-Fla
MGW-Fla's Avatar
Yeah its magical stuff, pricey, but worth it. Radio Shack used to carry it, but I went to get some about 6 weeks ago & they've replaced it with their own brand. I passed.
Old 03-28-2014, 12:03 AM
depami
depami's Avatar
Music stores often carry it for sound panel potentiometers, etc.
I sprayed trailer connectors and literally watched lights go from nil to full bright in seconds.
Old 03-28-2014, 12:11 AM
77tony
77tony's Avatar
Accidently knocked over a full bottle by mistake and lost half of it
Old 03-28-2014, 09:07 AM
Wisconsin Joe
Wisconsin Joe's Avatar
What's the difference between the stuff in the bottle and the spray stuff? I got a can of the regular spray (not the 'Gold') at Radio Shack this winter. It seems to work very well.
Not cheap at $16 for a small can, but worth it.
Old 03-28-2014, 10:45 AM
GlenL
GlenL's Avatar
I used it on the switches and pots in a 40-yo stereo and the results were great. Just took off the top and soaked the business parts while working the *****/switches. It works like new.
Old 03-28-2014, 10:53 AM
auzivision
auzivision's Avatar
2 X on the seat switches. Fixed mine using this years ago and they still work
Old 03-28-2014, 02:24 PM
Leon Speed
Leon Speed's Avatar
Thanks for the tip. Pricey but it sounds worth it.
Old 03-28-2014, 03:01 PM
F451
F451's Avatar
I'm going to buy a couple gallons and use my garden sprayer to douse my S4 front to back, top to bottom. Awesome!
Quick Reply: Electrical magic Deoxit, yes it`s true, it works !
