928 Forum 1978-1995
Sponsored by: 928 Specialists
Ride height
Old 04-01-2014, 02:05 PM
georges 928S
georges 928S's Avatar
Default Ride height
Hi Guys, I just came back from a suspension specialist who checked my ride height and told me its set up to factory setting, and he thinks its my tires. at this moment I have 215/45/17 front and 255/40/17 rear. what size tires should I put on to raise the front and rear and keeping the same 17 inch wheels. I will appreciate your feedback. thanks Ed.
Old 04-01-2014, 02:31 PM
uncre8tv
uncre8tv's Avatar
Cut a length of coat hanger to spec and double check yourself to be sure. Curious if they SWAG'd it or actually checked at the correct points (tire/well gap is famously variable.)
50 or 55 profile up front would raise it, but seems a really odd way to go. Especially since sidewall profile is fairly impactful on handling.
http://jenniskens.livedsl.nl/Technic...2/MyTip291.htm
Old 04-01-2014, 02:34 PM
FredR
FredR's Avatar
What width/offset are your rims? Your avatar suggests cup style rims and they are usually configured for a 225 section up front irrespective of whether they are Speedline or ANother.
Rears seem what would be expected on that type of wheel.
If your ride height is OK why would you want to increase it- deep potholes in your neighbourhood?
Regards
Fred
Old 04-01-2014, 08:30 PM
Fogey1
Fogey1's Avatar
Originally Posted by georges 928S
...I just came back from a suspension specialist who checked my ride height and told me its set up to factory setting, and he thinks its my tires.... I will appreciate your feedback. thanks Ed.
I'm sorry to be dense but he thinks what is your tires? Here are a number of links to ride height threads, many with excellent pictures.
https://rennlist.com/forums/928-foru...de-height.html
question re: Ride height
http://www.928.org.uk/13-setting-the-ride-height.html
Setting the ride height on the Porsche 928
https://rennlist.com/forums/9864908-post2.html
GTS ride height
https://rennlist.com/forums/928-foru...ml#post9309497
S4 MY89 Suspension/Ride Height Questions
https://rennlist.com/forums/928-foru...surements.html
Ride height measurements...
https://rennlist.com/forums/928-foru...ight-poll.html
ride height poll
If it were me, I'd pay attention to this post:
https://rennlist.com/forums/7319027-post26.html
I ran sharky at 155-160 front and it handled quite nice with no rubbing-bottoming issues.... the race 928's are WAY lower....I would guess (since I never measured it) both the widow and lemons were under 110mm when 1st lowered.... but both handled BETTER as I the suspension was raised...both would bottom harshly causing a bit of bump steer when super low....as the suspension was raised the suspension would absorb the bumps better with more control...and no harsh bottoming....
Lemons is at its highest front ride height ever due to the low starter...& it also is handling the best it EVER has.....
Old 04-01-2014, 10:58 PM
MGW-Fla
MGW-Fla's Avatar
Wouldn't you want at least a 225 tire width up front on a 928?
Old 04-01-2014, 11:26 PM
toofast928
toofast928's Avatar
Ed did I read this right. Your suspension specialist wants to correct the ride hight with taller tires?
Old 04-03-2014, 12:03 AM
axis of evil
axis of evil's Avatar
you have to get a giggle out all the posts that use bits of welding rods and bolts etc.
just use a tape measure.
That's what they are for.measuring!
Old 04-19-2014, 12:26 PM
Magnus Rostadmo
Magnus Rostadmo's Avatar
Maybe his suspension specialist in fact is exactly that ��...and have found that his car has correctly adjusted ride height but runs to low in the front due to the fact of the to small diameter of the 215/45-17.....should be 225/45-17...the 255/40 in the back has correct diameter.
Old 04-19-2014, 02:17 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Difference in rolling radius between existing 215 and proposed 225 tires is negligible-- ~~4mm if it's the same brand/model tires. That's not a make-or-break on ride height.
Go drive the car long enough to get the suspension settled again (50-100 miles) and measure the height yourself to verify. The links shared above offer several acceptable methods. I use welding rod or wire coathanger cut to lengths, as go/no-go gauges. Use whatever method works for you.
Old 04-19-2014, 02:55 PM
GlenL
GlenL's Avatar
I use short pieces of scrap wood.
Why? Because it's very hard to measure the front sides correctly. Once you've got a set it makes the job easier and I've measured a bunch of cars a bunch of times. The time to make them is more than paid for.
OP: What's the problem? If the suspension is set correctly than it's correct. We're all missing something here. You think the car is too low?
Quick Reply: Ride height
