928 Forum 1978-1995
Sponsored by: 928 Specialists
TT bearings
Old 12-30-2014, 06:37 PM
pol
4th Gear
pol's Avatar
Default TT bearings
Porsche 1988 928 S4
I’m about to proceed with TT bearings replacement.
Stock bearings are *** 6006 C5  impossible to find
I was able to locate NTN TS3 6006.ZZ.C5 (C5 is that matter )
Have any used those bearings? Advice plz ?
I know about Constantine bearings but they are very expensive , comparing to
NTN 3 for $100 CDN
Old 12-30-2014, 06:48 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Jager in Canada sells the bearing and the inner liners. You might check with them
Old 12-30-2014, 08:07 PM
Hilton
Hilton's Avatar
edit: Is your '88 an auto or 5-speed? my memory (possibly wrong - I've only had 5-speeds) says 88 was the year when Auto's changed to the thicker drive shaft, and thus use a different bearing?)
Hmm.. good question, I haven't looked for these bearings in a while.
Search turns up a Honda part 91062-HN8-013 for what appears (i.e. a guess on my part) to be a 6006 with C5 tolerance:
http://www.partzilla.com/parts/detai...2-HN8-013.html
Or more expensively on Amazon:
Amazon.com: HONDA 91062-HN8-013 BEARING (6006) (C5): Automotive Amazon.com: HONDA 91062-HN8-013 BEARING (6006) (C5): Automotive
Old 12-30-2014, 09:00 PM
Black Sea RD
Former Vendor
Black Sea RD's Avatar
Check with Roger at 928sRus, he sells replacement bearings and inserts too.
"Clementine," guess that's close...
Happy New Year,
Old 12-30-2014, 09:44 PM
pol
4th Gear
pol's Avatar
Thx guy
My apology Constantine , feel so stupid now
Happy new year!!!!!
It is 88 S4 auto
Old 12-30-2014, 10:20 PM
sstrickstein
sstrickstein's Avatar
Anyone know if a clunking sound on initial acceleration in an auto could be a loose torque tube bearing sliding down the shaft and hitting the next bearing? Does it at about 1800 rpm on initial acceleration and then not again until I stop and take off again.
Old 12-31-2014, 09:09 AM
GeorgeM
GeorgeM's Avatar
This may answer your question:
https://rennlist.com/forums/928-foru...-balancer.html
Old 01-19-2015, 07:21 PM
sstrickstein
So I had my car on the lift and looked at the inspection hole at the back of the torque tube. In the window I could see what looked to be the "Rubber Spring" from the back of my torque tube damper. I used a long screw driver and pushed the rubber spring back up the tube an inch or so.... Now the clunk is gone. I find it weird that the damper is in that location. I thought it was further up the tube. Here are some pics.
Old 01-20-2015, 01:26 PM
davek9
davek9's Avatar
The large weight is heavy and the rubber is shot, so it's moving back and forth and pushing the bearings out of place.
The TT needs to be serviced, period.
Nothing in there should be loosely moving about.
Go with the Super Bearings from Black Sea R & D and forgetaboutit
Old 01-21-2015, 10:15 AM
sstrickstein
I'm thinking that I pull the Trans back and just pull the damper out. No noise coming from my bearings.
Old 01-21-2015, 10:38 AM
davek9
davek9's Avatar
If its a manual you can drop the TT w/o too much trouble and service it.
If it's an Auto that's not going to be possible to move the trans back enough to get anything out of the inside of the TT, the TT can be removed by removing the upper bell housing and moving the trans back, about an inch is all you get w/o removing the rear suspension. (search for the write-up's).
With stock bearings (if they are still in the correct positions) w/o the balance weight you will have TT vibration, there is no "easy" fix here.
Old 01-21-2015, 10:49 AM
sstrickstein
I've had a small Trans leak. I'm thinking some of the fluid got into the tube and caused the rubber spring to slide off. I'll take a look. I'm planning on a Trans removal anyway to replace the input seal and have the torque converter tested for leaks. I'll handle this then
Old 01-21-2015, 11:38 AM
davek9
davek9's Avatar
Just to give you an idea of what your dealing with, here is a pic of whats in there (86.5 Auto).
Also show is the Super Bearings compared to the old original.
On both of my cars the rubber and the bearings were shot.
Remember the Drive Shaft spins at the same RPM as the engine, and on an Auto it is always spinning when the engine is running as it is connected to the Flywheel.
This job can be done on a Saturday on Jack stands by one person.
Good luck, let us know how it went or if you get stuck.
Old 01-21-2015, 02:03 PM
sstrickstein
Not to be a cheap skate... But why could I not rebond the damper springs to the damper and bond the assembly back to the tube? Has anyone ever tried this?
Old 01-21-2015, 03:02 PM
Sander_Baas
Sander_Baas's Avatar
I`m also in the middle of rebuilding my TT and I found these bearings:
http://www.ebay.com/itm/X41-TRX500-R...-/281399410233
also 6006 C5
was thinking about getting them.
Best regards
Sander Baas
Quick Reply: TT bearings
