928 Forum 1978-1995
Sponsored by: 928 Specialists
86.5 Intake / Engine Harness / Timing Belt
Old 03-22-2015, 09:33 PM
depami
depami's Avatar
Default 86.5 Intake / Engine Harness / Timing Belt
Well here we go. On stands, hood and cross brace off, ready for disassembly, cleaning, inventory and parts list for Roger.
Some history here.
Just now getting back to it. Came to the conclusion that engine harness is shot. Chased my tail to no end on ever changing electrical issues. Last pic shows examples of cracking harness.
I’ll start with intake then evaluate harness accessibility and decide if timing belt will be concurrent or follow separately.
Don’t know best stand height but I’m sure I’ll need to go under so this is lowest that will accommodate that.
More to come.
Old 03-22-2015, 09:42 PM
bureau13
bureau13's Avatar
I have some connector boots that are cracking like that. Does that really mean an entire harness is needed? Is there no way just to replace the connectors and boots?
Old 03-22-2015, 10:06 PM
depami
depami's Avatar
You may be able to replace connectors and be fine but it really depends on the condition of your harness.
I started replacing connectors but every time I touched something else, there was another problem. Then I scored a smoking deal on a new harness on ebay so here we are.
Old 03-22-2015, 10:45 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,278 Likes on 1,263 Posts
good luck on your restoration,
on my 86, 5 speed it had lots of new parts and it still wouldn't run.
Last thing was to swap in a good condition engine harness.
I did this in a parking lot out in LA it took 5 hours,
once all of it was hooked up hit the key and she fired right up ,
drove it back to Denver likity split,
only issue was a leaking oil fill tube so that made a mess.
Kens rockin this beauty now
Old 03-22-2015, 11:04 PM
Wisconsin Joe
Wisconsin Joe's Avatar
You can certainly replace individual connectors if you wish.
That may even solve the problem for a little while.
The downside of doing that is that you are addressing symptoms, not the real problem.
And the real problem is that the entire harness is 30 years (or so) old, and has been living in a "rather unfriendly" environment for that time.
If the connectors & boots are cracking, then the insulation on all the wires probably isn't too far behind.
The general procedure seems to be to fix individual spots until the frustration gets to be too much, replace the entire harness, and then say "I should have done that a long time ago."
Old 03-27-2015, 12:20 AM
depami
depami's Avatar
Default Small Progress
Old 03-28-2015, 01:29 AM
depami
depami's Avatar
Default Pleasant Surprise!
Old 03-28-2015, 04:47 AM
ashtuzhed
4th Gear
ashtuzhed's Avatar
Looks cool,
Old 03-28-2015, 09:58 AM
Avar928
Avar928's Avatar
How much are new harnesses? I'm replacing mine when I pull the engine out. I only see Carl's which is a bit pricier than I want but probably should expect.
Old 03-28-2015, 10:35 AM
linderpat
linderpat's Avatar
Received 2,259 Likes on 1,259 Posts
Denny - store that fan upright - all the viscous fluid will leak out otherwise!
BTW, those cam gears look perfect.
jbrob007 (06-04-2023)
Old 03-28-2015, 11:36 AM
depami
depami's Avatar
Last I checked they were around $1700. I scored a brand new old stock one for $400 on ebay. Thanks again for the tip Mark.
Thanks, I forgot that about the fan.
The gear condition was a pleasant surprise. I have no idea how many miles are on the belt but I know it's been on there more than ten years. I'm sure most will suggest to change it due to age alone. Of more concern than the belt are the WP, idler, and tensioner so I'll likely be going in there too. Comments anyone?
Old 03-28-2015, 02:39 PM
linderpat
linderpat's Avatar
I would not pull out those cam gears. No need to.
Old 03-28-2015, 09:44 PM
SwedeInSiam
SwedeInSiam's Avatar
I made my own engine harness for about $50 in materials from the local hardware store and some connectors from ebay.
Wire colors are not same but size and function are.
Old 03-29-2015, 09:52 PM
depami
depami's Avatar
Default Piece of Cake!
Funny how one thing leads to another on these cars.
What are options for getting these "tested and tuned"?
Success, old fuel harness is out!
Here's the new but its not in yet.
Are there fuel lines in there that need to be change?
Name:  Fuel Lines 2.jpg
They all appear to be metal. Where do Greg's go on this car?
Name:  Fuel Lines 3.jpg
Stay tuned. There's much more to come and I'm sure I'll need lot's of advice.
Thanks for the feedback guys,
Denny
Old 03-29-2015, 10:19 PM
Five-8
Five-8's Avatar
New engine harness from Carl was just south of $700.00 for my '82.
Is a thing of beauty.
Completely plug n play.
Highly recommended.
Cheers,
Quick Reply: 86.5 Intake / Engine Harness / Timing Belt
