150 Amp Alternators
#31
The webpage is ready now - and we can take orders for either model of alternator.
http://www.928motorsports.com/parts/alternators.php
#32
Anything special about the rebuild that Bosch did for you? I have a relatively new Bosch rebuild, and am in the conceptual stages of a front primary wiring upgrade of some sort. Probably a "next winter" project now that I actually have a winter projects option that doesn't reduce drive time.
#33
Rennlist Site Sponsor
My auto electric rebuilder (personal, not 928 Specialists) said that he could get several different regulators, with different temp curves...
#34
Electron Wrangler
#35
Electron Wrangler
Alan
#36
I run a 130 Bosch reman coupled with LED conversion, deoxit on every electrical connector, fuse, & relay. Have also changed out most major grounds as well. Electrical issues due to age are a big problem on our cars and need to be properly maintained as Speed noted.
I think that more amps going into the system causes less stress on the alternator and the electrical system especially during the summer. Heat decreases the efficiency and is one reason we have cooling shrouds.
Every time a new load is added to the mix the alternator and regulator must compensate. Increased alternator output lessons the stress and speeds up the charging rate/time to the battery.
200amp is overkill but 130-150 amps keep our cars electrical system and computers running more consistently, with less stress.
Just think of an under powered a/c system. The compressor continually engages which will soon wear it out much the same way an alternator that is continually trying to keep up with demand does especially under harsh conditions.
Just my opinion based on experience.
#37
Electron Wrangler
Faster charging is only good if you stay under the max charge rate for the battery which varies with temperature. Overcharging a battery is much worse for the battery (life & death) than undercharging it (takes longer to reach full charge). You have to understand the limits before you change things. Having a higher current capable alternator actually changes exactly nothing about how the battery will charge. The only things that affect charging are the alternator nominal voltage set-point and the temperature & load deration factors in the regulator (and the effects of other system loads).
*many high current alternators are just regular alternators with different regulators - these end up more highly stressed. I don't believe that of Carls' versions but it is the case with some.
It is really not helpful to state things that clearly cannot be true. However you are not alone here - almost nobody understands alternators. They only seem to be simple - they are not easy to understand in context.. especially wrt battery charging which is also by no means as simple as it seems to be.
I'm not trying to be a jerk here - just trying to keep the facts straight. All kinds of drivel is posted about alternators every year here by many people - it's no wonder folks aren't developing any better understanding. I just try to point out the major errors and keep the story straight.
Now we shouldn't really have to understand all this - Porsche should have just done a better job in the first place.
Alan
#38
#40
So if I understand you correctly it really does not matter how many amps the alternator puts out...so a 30 amp alternator will be as efficient as a 60amp due to the fact that it runs continuously and the charging rate is constant.
That funny because the manufacturer of my boat motor as well as all the others decided that the 50 amp alternator was not sufficient to fully charge the battery during extended periods of low rpm use when under extra load from accessories.
According to your theory since the battery can only take x amount of charge then we don't even need 60 amps. Is that your conclusion?
As far as a/c goes, park your car/suv in the sun with the ac running and see how well it performs after an hour.
I am curious as to what causes the lights to dim at idle when the ac kicks on and why does the idle drop in some cases as well. I had this symptom until I converted to the 130 amp. Cleaning contacts helped but the 130 alt made all the difference.
#41
A higher rating alt MAY deliver more current at lower RPMs. Depends on design. That's what your boat dude was really saying, and some here desire, whether for real or imagined reasons.
A battery is a chemical reaction, and its slow, and you dont 'dump' Amperage into them to 'fill' them quicker.
It will answer for the draw you have, and work to slowly charge the battery based on temperature..which Alan has covered quite well...because batteries are chemical reactions, and temperatures are important.
If you have 50a of total draw, and your use-case isn't trolling the waters or hours at idle speeds in traffic, a 'larger' alternator is just making you wallet light.
A 150A alternator in a 60a environment, is a 60A alternator.
#42
I agree that a 150amp is a 60amp in a 60amp environment. That being said I and others feel that a 60amp in not a 60amp in our environment due to the extra pull required to overcome the resistance encountered by old wiring, old light bulbs, corrosion and other sundry electrical issues that go hand and hand with a 25 plus year old car that relies on good constant electrical current to operate properly.
Resistance is futile!
Your statements work in a perfect environment where everything is pristine. Laboratory conditions. Not real world as described above for most of us.
#43
A 150a alternator is not the solution to those problem. It is the solution to a bumper to bumper wiring fire.
#44
Electron Wrangler
That you may have got increased idle current performance in your high max amp alternator was DESPITE the higher current windings - not because of them.
In this case regulator changes and perhaps design changes (pulley ratio, case design, rotor design etc) gave you better idle performance. The higher current stator windings certainly made the idle current capability worse than they could be in the same design with a lower (say stock) max current rating.
So be careful what you look for - you may get the opposite of what you think you are getting (and pay $$$)
Alan
#45
Speed, as I said earlier, I have addressed 70 percent of the resistance due to outdated wiring and other things that draw extra current due to their age and design.
My dim and idle drop became nonexistent after the 130 amp install, which has led me to my conclusions. Nobody is arguing that the stock alternators are not sufficient under normal operation above 1500 rpms. The issue rest solely with low rpm ( idle in traffic, hot days for extended periods) charging.
Alan conceded that a higher output amp will perform better under these conditions given the totality of circumstances.
In a perfect world we could completely redo our wiring and the low idle charging issue would be moot. That's not the case, so we look for cheaper alternatives that appear to compensate albeit right or wrong.
Electrical issues rank right at the top in this forum especially for the later model 87 and up cars, chiefly because of the enhanced systems that rely on constant electric current.
A 60 amp system will not correct this issue with all things considered absent a complete rewire as you stated.
