928 Forum 1978-1995
Sponsored by: 928 Specialists
Cross Brace Alternative
Old 10-14-2015, 07:14 PM
hans14914
hans14914's Avatar
Default Cross Brace Alternative
Found some nice off-the-shelf parts to assemble an all aluminum strut brace. Only custom part required is the mounting plates (represented here by the 3d-printed part for test fit). Sent the files over to the waterjet shop this afternoon, should have it mounted by the end of the week.
Thoughts? I kind of like the black look, but same supplier has the tube in polished as well.
Old 10-14-2015, 08:52 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Hmmm.... Hood gap adjuster! Nice!
Looks great. Are you reinforcing the mountings to the body at the same time? The original brackets depend on the boltup to the crossbrace to keep from bending vertically under compression load. Will be interested to see how the original mounting brackets fare without the support.
Old 10-14-2015, 08:53 PM
mark kibort
mark kibort's Avatar
looks effective!
Old 10-14-2015, 08:57 PM
SMTCapeCod
SMTCapeCod's Avatar
I like it. I also like black though I can see some preferring polished. Is it powdercoat?
Would be extra convenient if were compatible with the a/c valve mounted on the crosspiece, or else shipped along with a solution for that.
I currently have the 928SP carbon fiber bar, and sourced a machined/powdercoated aftermarket motorcycle bracket to deal with the incompatible diameters.
A laser etched or machined logo would be cool, model designations, manufacturer script if free of TM constraints....may not be worth the effort but it seems like it would be tough to find someone to do a good job of that on the round surface.
Actually, is it all tapered round tubing, or is it oval? I think the latter would add an interesting look. And depending on the thread, would allow easier adjustment with a wrench.
I previously had a Schnell brand carbon fiber (look) bar that had heim jonits on the ends. I liked the adjustability, but not the faux finish. The fittings at the ends were oriented to mount with a cross bolt that passed between two vertical plates on the mounting plate. Not sure why.
Old 10-15-2015, 02:04 PM
hans14914
hans14914's Avatar
Its anodized a matte black. its pretty hefty drawn aluminum tube with LH and RH threads to make adjustments quick and easy. Rod ends are also black anodized, but they have been bright tanked first, so they are a more shiny black finish.
I am having the waterjet shop cut a stack of the mounting tabs if anyone wants a set.
Old 10-15-2015, 03:24 PM
Tom in Austin
Tom in Austin's Avatar
I like it Hans, are you going to offer as a kit?
Old 10-15-2015, 04:52 PM
SeanR
SeanR's Avatar
I like it, and it just might work better for those of us running charge pipes down the side.
Old 10-15-2015, 05:22 PM
PorKen
Inventor
PorKen's Avatar
Nice!
Old 10-15-2015, 05:46 PM
ROG100
Basic Sponsor
ROG100's Avatar
Are you going to add your logo
Old 10-15-2015, 06:02 PM
MjRocket
MjRocket's Avatar
LMAO!!
Old 10-15-2015, 06:36 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,220 Likes on 472 Posts
Nice Hans.
I like the black color too.
Old 10-15-2015, 11:24 PM
jbrob007
jbrob007's Avatar
Here... TAKE MY MONEY!!!! Very nice custom look without appearing over the top.
Old 10-15-2015, 11:29 PM
BIMMERMIKE
BIMMERMIKE's Avatar
What is price?
Looks good!
Old 10-16-2015, 12:34 AM
Ducman82
Ducman82's Avatar
i have that same set up under the car. might as well make it match. I'm down.
Old 10-16-2015, 02:55 AM
MjRocket
MjRocket's Avatar
Oh what the Hell....If Hans builds it, I buy it!
He might as well be my Crack dealer.
Quick Reply: Cross Brace Alternative
