928 Forum 1978-1995
Sponsored by: 928 Specialists
Building a replacement cap for sealing headlamps after converting to HID or LED
Old 03-08-2018, 04:42 PM
  #196
Bigfoot928
Bigfoot928's Avatar
Got my caps in. They look great and excellent quality~! Getting them installed ASAP~!
Old 03-12-2018, 07:07 PM
  #197
BIMMERMIKE
BIMMERMIKE's Avatar
Received my H4 sealing caps(nice work Ed!) and received 2 sets I only require one set.
Anybody here require a set?
I'm in Canada so preferably shipping within Canada but open to options.
Old 03-12-2018, 09:14 PM
  #198
JBGold07
JBGold07's Avatar
I would like them Mike...
Old 03-12-2018, 10:44 PM
  #199
BIMMERMIKE
BIMMERMIKE's Avatar
Local 928 owner wants the caps
Old 03-12-2018, 11:43 PM
  #200
Ed Scherer
Ed Scherer's Avatar
FYI, after a few months of little or no interest, the last batch of 9 pairs was gone in about 48 hours. I should be able to make another batch by the end of the month. I've got a new style of outer ring seals on order; that should eliminate the one detail that was really giving me trouble (reliably making a strip seal into a ring seal with a glued splice) and should speed up production a bit.
Thanks for the comments about my dad. I've spent most of the last 7 of 7 days/evenings in either a hospital or rehab facility (support/care management/etc.), so not much spare time. But things are looking up for now.
Old 12-18-2018, 06:51 PM
  #201
rjtw
rjtw's Avatar
I've had the LED headlights on my car for over a year now and continue to enjoy the conversion. Definitely a big improvement. My only complaint is the lack of a good H3 (fog light) LED retrofit to match. The fog lights now look so yellow and out of place next to the 5000K headlights! OTOH, the headlights are now so much better that I don't NEED to run the foglights for ordinary night driving like I did with the H4 bulbs.
However, my real reason for posting: Occasionally, turning on the foglights causes the headlights to operate improperly (I think it turns on both high and low beams at the same time). Flashing the headlights or turning them on and off fixes it, but it's a pain. Did someone mention that using a new relay or some jumper would solve problems with the headlight/foglight interaction? This is for an '83 US 5-speed. Any direction appreciated!!
Cheers.
Rick
Old 12-18-2018, 10:28 PM
  #202
Ed Scherer
Ed Scherer's Avatar
Replacing the fog light relay with a standard "53" relay should do the trick.
See the thread Headlight / Foglight interaction prob with LED bulbs. There's even a post in that thread (post #37) that specifically mentions that it works on an '83.
Old 12-19-2018, 11:15 AM
  #203
Majestic Moose
Majestic Moose's Avatar
Cheers.
Rick
Replacing the relay with a "53" restored full functionality on my 1983 5 speed.
Try this for the H3 foglamp bulbs.
Amazon Amazon
And these for the driving lamps. https://www.superbrightleds.com/more...t-car/169/766/
Old 12-20-2018, 03:13 AM
  #204
rjtw
rjtw's Avatar
Hi Moose,
Wow! Thanks for the links!! Looking sharp!! Yes that’s exactly what I’m after!!! On those H3 bulbs, do they maintain the sharp horizontal cutoff of the original bulbs? Are any modifications to the light assembly needed?
cheers!
Rick
Old 12-20-2018, 10:14 AM
  #205
Majestic Moose
Hi Moose,
cheers!
Rick
I'm not sure where the cutoff was with incandescent bulbs. There is a cutoff but it might be caused by the top lip of the bumper opening above the lamp as it is pretty high. I would not drive with these on with oncoming traffic, but you are not supposed to with foglamps and it is illegal under clear conditions. They are not blinding during the day however so I run the marker lamps and foglamps as daytime running lamps, headlamps are down and off.
No modifications needed, they are just short enough to fit behind the shield inside the lens.
Old 12-20-2018, 09:18 PM
  #206
rjtw
rjtw's Avatar
Just got those H3 bulbs on order from Amazon! They are rated at 1000 lumens but don't show a color temperature -- I'll hope/assume it's around 5500K which would match the headlights. FWIW, the magic distance seems to be 32mm max from the mounting plate to the tip of the bulb -- that's the size of the original H3 and presumably any bulb much longer would run afoul of the internal shield. I did go crazy looking on Amazon at many other H3 bulbs but there are very few which meet that specification. There are one or two others that are under 32mm but extend far out the back side (like these:
https://www.amazon.com/CIIHON-Lights-1900LM-Headlight-Warranty/dp/B07FVX96YL/ref=sr_1_21 https://www.amazon.com/CIIHON-Lights-1900LM-Headlight-Warranty/dp/B07FVX96YL/ref=sr_1_21
and
https://www.amazon.com/SOCAL-LED-H3-Fanless-Conversion-6400LM/dp/B01LA5UKK8/ref=sr_1_66) https://www.amazon.com/SOCAL-LED-H3-Fanless-Conversion-6400LM/dp/B01LA5UKK8/ref=sr_1_66)
. Don't know if those would work. So I went with the H3s that Moose found!!
I ended up ordering some slightly different driving light bulbs though by looking around on Amazon instead. There are a TON of these BA15s LED bulbs to choose from. I wanted to stick to something close to 5500K. So I ended up ordering two different bulbs, one is 2W (and unknown lumens, but which I think is good for about 200 lumens) and the other one is rated at 900 lumens (and unknown wattage). They're both 6000K. I'll try 'em both and report back.
H3, from Moose:
Amazon Amazon
Lower wattage driving light:
Amazon Amazon
Higher wattage driving light:
Amazon Amazon
Old 12-22-2018, 07:15 AM
  #207
Dave H.
Dave H.'s Avatar
Location: Seattle - it's not Hell, but you can see it from here!
Ed, are these the correct bulbs?
LED H4 with LUXEON Z ES LED bulb
Old 12-23-2018, 01:38 AM
  #208
Ed Scherer
Ed Scherer's Avatar
Thumbs up
Yes.
Old 12-29-2018, 11:24 PM
  #209
rjtw
rjtw's Avatar
As an update to the H3 bulb chase, I found a direct replacement LED H3 that I am very happy with now. And sorry for hijacking the H4 thread with H3 talk, but for anyone else upgrading both the headlights and the foglights (and even the bayonet bulb driving lights), perhaps this can help tie things together! https://rennlist.com/forums/928-foru...l#post15529439
Old 09-06-2020, 09:14 PM
  #210
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Wow.
How'd i miss this!
Quick Reply: Building a replacement cap for sealing headlamps after converting to HID or LED
