Building a replacement cap for sealing headlamps after converting to HID or LED
#211
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i need to fab up a housing for my bumper lamps (driving lights to avoid the heavy stock housing.
i may carve/sculpt from willow or basswood.
or maybe i can get a block of dense foam to sculpt.
#212
Electron Wrangler
As I posted in the other H3 thread - can anyone confirm fit of in an S4+ in fog & Aux headlight locations?
Alan
Alan
#214
They will be; I still have materials for another 18 pairs. I've just been extremely busy and haven't had a chance to make another batch. Maybe in a couple of months or so.
#217
fogging issue sometimes
Resurrecting an old thread...
I have been running H4 LED's in combination with these awesome covers made by @Ed Scherer for several years now. See post 87 for more details.
Occasionally, I notice fog inside the H4 headlight lens when I arrive home. Usually, these trips are 20 minutes or so. I don't have any long-distance observations. I should note that I live in Portland, OR, where the winter weather is usually on the brink of fog, temperatures in the 40's, and relatively high humidity. I am curious if others using these covers are also experiencing occasional fogging. @Ed Scherer do you have any suggestions on how I might mitigate this? Would more airflow help? Or is it possible that too much airflow is getting in? Your thoughts are appreciated.
The pictures below were taken after a 15-min drive with the lights on, temps in the low 40's and no precipitation.
#218
Inventor
Needs a heater element inside. Drill the city-light bulb hole and put an incandescent bulb in there
U-928 (02-05-2024)
#219
#221
The new H4 LED from Philips is a direct fit.
I installed the LED lights on our old Volvo and it made a difference.
Åke
H4 LED Spotlight bulb Philips Ultinon Access 2500
Direct-Fit / Replaces halogen lamp
Article number: 11342U2500C2
Technical information:
Application: High beam, low beam
Socket: H4 (P43t-38) / H19 (PU43t-3)
Designation: LED H4/H19 11342 12V U2500 C2
Operating temperature: -40 °C/+85 °C
Range: Philips Ultinon Access
Technology: LED
Approval ECE R37: No
Approval ECE R10: Yes
Non-polarity: Yes
Lifespan: 1500h
Lumen: 1500 lm /1000 lm
Color temperature: 6000K
Wattage: 20W
Voltage: 12V
Philips Art no: 11342U2500C2
Manufacturer Philips
EAN number 8719018026057
Åke
Technology: LED
Non-polarity: Yes
Lifespan: 1500h
Wattage: 20W
Voltage: 12V
#222
Awesome, and thank you for this Philips alternative. It's nice to see LED packaging evolve to be more of a suitable drop-in replacement.
Buying: Where did you get yours? I found only a few places that sell it in the USA.
https://www.ledperf.us/philips-ultin...-p-120268.html
ebay
Lumens: The stated output is 1500 lm (lhi beam) /1000 (low beam) per bulb. This seems pretty low compared to the "stated" outputs from other H4 LED's. The ones I currently are using are 4500 per bulb, assuming that is for both Hi/low beams, but still double the output. Now we know that lumen claims can be dubious unless tested. (see video from other RL post). I guess the best way to tell is to test myself.
youtu.be/b6s3jwy4ZZA?si=iiMD2h4MxHXCgpAv
ebay
Åke
Technology: LED
Non-polarity: Yes
Lifespan: 1500h
Wattage: 20W
Voltage: 12V
Åke
Technology: LED
Non-polarity: Yes
Lifespan: 1500h
Wattage: 20W
Voltage: 12V
#223
I bought the LED H4 lamps at a local store.
Lumen is not that impressive, but it is a big difference to previous halogen lamps.
Use google translate for translation from Swedish to English.
I think you can order here:
info@hova.com
https://www.philips.se/c-p/LUM11342U...e-all-benefits
info@hova.com
#224
I found these LED bulbs from Woody Peck based in the UK and the bulb is plug and play with exist wiring harness using a Cree chipset.
https://woodypeck.com/product/porsch...adlight-bulbs/
