928 Forum 1978-1995
Sponsored by: 928 Specialists
Locked Out
Old 06-16-2016, 11:02 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
She hates you...
Old 06-16-2016, 11:11 AM
mikeb7
mikeb7's Avatar
That's a cruel thing to say, but it has crossed my mind.
>>Any thoughts on why the car randomly locked down while sitting there with the key in the ignition? It had been similarly sitting for two weeks. Closed the door, walked away for a few minutes, came back, went to open pass door, and suddenly heard the whirring of the locks. Why, my new friend, why?
Old 06-16-2016, 12:09 PM
medipedicman
medipedicman's Avatar
Originally Posted by harveyf
If you search this forum, you will find a similar thread that has a link to the actual Porsche diagram for the J shaped wire that can be used to slip between the door and the glass and release the lock. I haven't done it myself (sounds like something we should all practice) but as I recall you are in effect pushing up on the underside of the lock shaft that protrudes through the top of the door panel. Like others said, a matter of minutes with the right tool and knowhow.
Only because you mention "slimjim" I don't think a traditional slimjim will work.
The one time I got locked out, the locksmith used a small inflatable bladder to spring the door. We snagged the keys with a wire and pulled them through the door. The bladder is probably the best from a standpoint of not tearing up the door seal.
It is sort of amazing that the 928, originally costing the price of a modest house, and having an alarm system, could be opened so easily with a tool found in factory literature, in a few minutes. I don't even know if the alarm will sound in this scenario.
Old 06-16-2016, 02:23 PM
Randy V
Randy V's Avatar
Keep the extra key in a separate location.
I know, crazy.
Old 06-16-2016, 02:56 PM
mikeb7
mikeb7's Avatar
Well, yes, generally do not carry every key I have for the car on one ring but, new car, still in the garage getting fettled, and power locks had appeared inop so far to boot.
Never expected it to randomly self lock, apparently unprovoked, after a couple of weeks. Don't know what triggered it.
Old 06-16-2016, 03:41 PM
davek9
davek9's Avatar
This..."Randomly walked up to the passenger door to open it and heard "whirrr".".
You disturbed the locking mech on the passenger side, may have been stuck.
In the future when working on the car leave a window open, or make certain to remove the keys from inside
Good luck w/ that "Dealer option"
Old 06-16-2016, 05:16 PM
The Forgotten On
The Forgotten On's Avatar
Your door mech is goobered up internally, my drivers side one does this as it is worn out. Either find an NLA replacement or get a good used one.
Old 06-16-2016, 08:55 PM
vanster
vanster's Avatar
You can also use a popsicle stick. Soften it up, put in the lock and keep working it until the wood hardens and it will become a key. "I am not a crook"
Old 06-16-2016, 09:01 PM
The Deputy
The Deputy's Avatar
Default Always be prepared...
Made one of those wood wedges and hooked tools and store them in the glove box for emergencies like this.
Brian.
Okay, I'm just being an idiot on purpose...instead of randomly as usual...lol.
Old 06-16-2016, 10:53 PM
mikeb7
mikeb7's Avatar
It looks like the factory wire trick will work. Been practicing on the parts car. I get it a couple of times, go back for one more test run before the real thing, and lose it again.
When you get it right it's stupidly easy. The other 99 times it feels impossible. I'll keep practicing.
And making better tools. Been practicing with coat hanger to easily adjust hook shape/size, but looks like the welding rod suggestion will do well when I'm ready for the real thing.
Old 06-16-2016, 11:45 PM
Randy V
Randy V's Avatar
Or you can go in through the secret floor hatch.
Try a search.
Old 06-17-2016, 12:12 AM
safulop
safulop's Avatar
Is it possible you have a secret aftermarket keyless entry system that has been interconnected? Mine shorts out internally all the time so I disconnected it. I often still hear it clicking randomly. My car used to randomly lock and unlock itself, because of this system. Just because you didn't get fobs from the PO, doesn't mean there is no such system installed.
Old 06-17-2016, 07:54 AM
mikeb7
mikeb7's Avatar
Don't know, haven't gotten far enough into the car yet to see whether there is an aftermarket alarm system on it. It's certainly possible.
I will keep working on the wire entry system. I'm saving popping the floor panel as my back up.
Old 06-17-2016, 09:30 AM
jwyatt8171
jwyatt8171's Avatar
I have seen videos of people unlocking cars with a tennis ball. It's on the internet, so you know it's true!
Old 06-17-2016, 10:34 AM
CJ8 2 928
CJ8 2 928's Avatar
The Deputy how do you get to the wedge or hooked tool if your car is locked ? I would suggest securing it under the rear bumper.
Quick Reply: Locked Out
