928 Forum 1978-1995
Sponsored by: 928 Specialists
Dexron VI OK in power steering?
Old 09-04-2016, 03:35 PM
bureau13
bureau13's Avatar
Default Dexron VI OK in power steering?
I did some thread searching, but never really found anyone definitively saying that this stuff was OK for power steering....and one thing where it seemed the manufacturer was not recommending it? I needed some to do my high pressure hose, and that's what I ended up picking up at Pep Boys...but if it's a bad idea I can probably exchange it...
Old 09-04-2016, 03:41 PM
Rocinante
Rocinante's Avatar
Probably okay, but why risk it? IIRC, owners manual and WSM say to go with Dex 3.
Old 09-04-2016, 03:47 PM
bureau13
bureau13's Avatar
I think they actually say "Dexron," Dexron III superseded that, and in turn was superseded by Dexron VI. The thing is, if I understand things correctly, current Dexron III fluids aren't licensed, so I'm not sure there is any real enforcement of the original criteria.
Old 09-04-2016, 05:00 PM
mark kibort
mark kibort's Avatar
Isnt the newest versions of Dextron (i.e. VI, etc) all backwards compatible for the older dextron III and others? says on the lable in most cases.
Old 09-04-2016, 05:30 PM
bureau13
bureau13's Avatar
Yeah, it does say that...I'm probably just paranoid about the statement (old, I think) about not using it in power steering applications.
It's probably a bit of a moot point, because I found the mostly-gone container of fluid I used when I replaced the reservoir and it's Dexron VI
Old 09-05-2016, 11:16 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
GM doesn't say not to use it, but they do say (or did the last time I looked) that it wasn't approved for usage in power steering systems. I suspect that only means that they haven't tested it in every power steering system, so the lawyer weasels won't let the marketing weasels say that it is OK...
Old 09-05-2016, 11:21 AM
bureau13
bureau13's Avatar
Yeah, that's the statement I saw...you're probably right about the reason for it.
Old 09-05-2016, 11:58 AM
soontobered84
soontobered84's Avatar
I've had it in my PS system for a couple of years. Come on in, the water's fine.
Old 09-06-2016, 01:50 AM
JHowell37
JHowell37's Avatar
I've been using it for a few years in my power steering and no problems. If anything, the effort is reduced slightly. Maybe due to the lower viscosity.
Old 09-06-2016, 10:07 AM
Taguid
Taguid's Avatar
I just used the Valvoline synthetic Dexron VI when I changed my PS hoses and it works just fine.
Old 09-06-2016, 11:00 AM
bureau13
bureau13's Avatar
Thanks for the info everyone. I'll go ahead and use the stuff I bought, if I can ever get this *^%$ing line off....
Old 09-07-2016, 06:30 PM
traxtar928
traxtar928's Avatar
Chiming in for Valvoline full syn Dex VI... works fantastic for me for 5 years of ownership.
Old 09-07-2016, 06:53 PM
soontobered84
Do they still make IV? I thought that VI had superceded IV.
Old 09-07-2016, 07:39 PM
traxtar928
traxtar928's Avatar
You're right... it was VI.
Old 09-07-2016, 08:52 PM
bureau13
bureau13's Avatar
I'm swapping my roman numerals...Didn't they go straight from III to VI? At any rate, I'm pretty sure I meant VI!
Quick Reply: Dexron VI OK in power steering?
