928 Forum 1978-1995
Sponsored by: 928 Specialists
GTS Pollen Filter
Old 01-11-2017, 08:00 PM
ROG100
Basic Sponsor
ROG100's Avatar
Default GTS Pollen Filter
If you have a 94/95 GTS be sure to check the pollen filter. My 95 had a lack of airflow through the vents.
As you can see the filter was totally clogged and even with the filter in place there was a small rats nest of crap in front of the evaporator.
Vacuum and new filter restored the service back to normal.
I am pretty sure that is the original filter from the factory 22 years ago.
Old 01-12-2017, 12:23 AM
Herman K
Herman K's Avatar
Default I carry...
them in stock
Old 01-12-2017, 12:27 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,575 Likes on 1,242 Posts
At least the filter did a nice job of keeping the evaporator fins clean.
Old 01-12-2017, 11:08 AM
ROG100
Basic Sponsor
ROG100's Avatar
I agree Rob.
The rats nest, I believe, was caught up on the filter and dropped when I removed it.
Old 01-13-2017, 01:29 AM
pcar928fan
pcar928fan's Avatar
Where I should that filter located in the car?
Old 01-13-2017, 02:30 AM
Dave928S
Dave928S's Avatar
^^ Remove the plenum cover, and you'll see the HVAC box centrally, with a cover which is secured in place by one small torx screw. You can see where it screws into in Rogers last photo (blurry speed nut). Remove the torx screw and then pull the cover to the front of the car to remove it. The cover has two holes in it (one either side) which are where the white locating pins, which you can see on the filter, keep the filter in place under the cover. Make sure those filter pins locate in the cover as you replace it.
Old 01-14-2017, 01:58 PM
ROG100
Basic Sponsor
ROG100's Avatar
I thought the pollen filter was only fitted to the superior RogerBox cars as the crapboxes did not have enough puff!!!
Old 01-14-2017, 02:46 PM
Rob Edwards
Archive Gatekeeper
Rogerboxes only need the extra filtration because they suck so much.
Old 01-14-2017, 03:21 PM
77tony
77tony's Avatar
Cabin filter below pulled from a fairly new MY15 991/16k. T
Old 01-14-2017, 04:33 PM
Randy V
Randy V's Avatar
Cat fight!
Old 01-14-2017, 05:42 PM
Rob Edwards
Archive Gatekeeper
Meh, it's not a cat fight, more like a battle of wits against an unarmed opponent. Like shooting fish in a barrel of ATF.
Old 01-14-2017, 06:00 PM
ALKada
ALKada's Avatar
Good Lord Tony, have you been driving in Beijing?
Old 01-14-2017, 06:41 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Tony lives downwind of a bunch of chemical and petro plants there along the gulf coast. Be glad that filter caught all that stuff! And if you happen to be walking outside, just don't inhale, mr. president.
I changed the pollen filter in the Honda DD at the end of its first (and again at second and third) year, and find it full of yellow Ponderosa Pine pollen. Really full. It may drive me to try and fit a filter to my pre-GTS car one of these days.
Old 01-14-2017, 06:55 PM
Randy V
Randy V's Avatar
Zing, POW!
Originally Posted by dr bob
I changed the pollen filter in the Honda DD at the end of its first...
End of its first what?
Old 01-14-2017, 07:19 PM
SwedeInSiam
SwedeInSiam's Avatar
In Thailand we don't need pollen filter since the AC recirc has to be secured in closed position due to all smoking stinking diesel pickup trucks
Quick Reply: GTS Pollen Filter
