4.5 vs 4.7
4.5 vs 4.7
Hi guys,
Quick question. Assuming 1979 4.5 litre and 1982 4.7 litre (both ROW, both K-Jet), apart from pistons (ie bore) what differences are there between the engines ?
For example, are the cranks the same ? Are the fuel injection systems (like say the fuel distributor) the same ? I guess water pumps are identical ?
What's different ?
Thanks in advance !
What's different ?
Thanks in advance !
Cranks are the same. Heads and valves are bigger too. Injection is the same basically but different warm up control pressure regulator..Pretty much everything that restricted airflow was " fixed" for the 300 hp S !
