79 928 fuel system..
I think someone's been using an S4 pump in Saudi Arabia in place of both pumps without any issues. Forgot his username. He posts a great deal, so I'm sure he will chime in.
Hoi
Hoi
I ran a CIS car using the later tank and pump set up for quite some time. The CiS pump has a built in check valve while it is in the banjo on later pumps so be sure to address that issue when trying this. It's possible but less than optimal
Its a car with some work done to the fuel system in the rear..that could end up in an S3 config, or back to 79 config...for about the same price I think.
I already have in the parts the came with it, an S3 pump/filter/mounting hardware.
Gotta drop the tank and see what's really all going on.
Basic Sponsor
The filters are the same apart from a screw in connector on one end of the filter - remove the screw in connector and you are good to go on the filter.
