928 Forum 1978-1995
Sponsored by: 928 Specialists
Did I just damage my car?
Old 04-01-2017, 03:57 PM
crushingday
crushingday's Avatar
Default Did I just damage my car?
So, I have heard a lot about porting and polishing my intake. I figured I would feed some fine sand into the intake to polish it and remove some carbon deposits and such. All was going well for a little while then all of a sudden the engine stopped and wont restart. any ideas?
Old 04-01-2017, 04:04 PM
Leon Speed
Leon Speed's Avatar
April fools. Busted.
Old 04-01-2017, 04:05 PM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
I think that's a great idea. Not sure what could have gone wrong.
Dave
Old 04-01-2017, 04:23 PM
drooman
drooman's Avatar
Received 2,011 Likes on 698 Posts
No worries, I'll send a flatbed. I need some green interior parts anyway.
Old 04-01-2017, 04:24 PM
skpyle
skpyle's Avatar
You did it dry. That's why it didn't work.
Mix the sand with water and pour it in the intake. Rev the engine a couple of times to ensure proper dispersion.
Old 04-01-2017, 04:31 PM
jorj7
jorj7's Avatar
I used ground walnut shells in mine. Harder then the carbon build up, but softer then the aluminum. Also the slow burning characteristics increases the octane rating of the fuel.
George
90 S4 Grand Prix White (Murf #5 - 210 mph top speed)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
Old 04-01-2017, 05:38 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
I dunno..somewhere...I wondered if Kibort would do it..
Old 04-01-2017, 08:11 PM
supercedar
supercedar's Avatar
Should I pour this wet mix directly into the MAF? What RPM do you suggest?
Thanks in advance
Thomas
Old 04-01-2017, 08:59 PM
Billu
Billu's Avatar
If I mixed with ATF would my shifts get crisper????
Old 04-01-2017, 09:43 PM
hlee96
hlee96's Avatar
Don't forget the fueling system. Save 1/3 of it and feed it gently into the gas tank through the sender. If it doesn't stop running, you're not doing it right.
Old 04-01-2017, 09:57 PM
skpyle
skpyle's Avatar
Thanks in advance
Thomas
Remove the MAF, you don't want to damage it. Pour directly into the shoe. Hold RPM's to about 2000.
Old 04-02-2017, 12:14 AM
928NOOBIE
928NOOBIE's Avatar
Um...hello...?
Are all of you trying to sabotage this poor guys car?
You have to pull the top radiator hose off and pour sand into the block or the water passages will just be full of crud and that brand new clean engine making all that extra power will overheat!
Amateurs!
Old 04-02-2017, 12:32 AM
skpyle
skpyle's Avatar
I am not worthy. (Hangs head in shame.)
Old 04-02-2017, 03:14 AM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
, don't know about the dry sand method, but I heard seanr put a vacuum line in a can of coke and held a rev of 6500 rpms to clean the oxidation off of the valve stems, said it worked better than deoxit.
Old 04-02-2017, 03:20 AM
Randy V
Randy V's Avatar
That'll buff right out.
Quick Reply: Did I just damage my car?
