928 Forum 1978-1995
Sponsored by: 928 Specialists
Pulling speaker wire into doors..who dunnit?
Old 04-24-2017, 11:01 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Default Pulling speaker wire into doors..who dunnit?
Is it a large challenge to pull speaker wire into the doors thru the plastic channel?
Old 04-24-2017, 11:23 PM
zekgb
zekgb's Avatar
IME it's unpossible without taking the door panels off.
Old 04-24-2017, 11:31 PM
Wisconsin Joe
Wisconsin Joe's Avatar
It wasn't really hard.
What I found to work well was a thin spring steel wire (fairly rigid) would go through the plastic channel. With a hook in the end of it, I could loop the wire over the hook and pull it through the tube.
I had zero success trying to push the wire through. It flexed too much.
And I agree that it's probably not possible without pulling the door cards. Or at least the effort of doing it that way is more than pulling & replacing them.
Old 04-24-2017, 11:51 PM
Speedtoys
Speedtoys's Avatar
Ok..coat hanger it is...its on the list of things to do soon now.
Old 04-25-2017, 01:11 AM
hwyrnr
hwyrnr's Avatar
coat hanger is what I used. not to bad I just took my time. no hook on the end I just taped the wire to the hanger and gently pulled it through the plastic.
James
Old 04-25-2017, 09:34 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,321 Likes on 1,295 Posts
before you remove the door panel,
just see if you can access the sheath via the armrest openings ,
you may be able to fish the wire through without door panel removal just the armrest.
Old 04-25-2017, 04:49 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Guessing that the speaker wires will ultimately attach to speakers you are installing. You --may-- be able to fish for them through the speaker openings if no crossover connections are needed. Otherwise the door panels will be off for terminations. At that point you can fish new wires through the plastic duct with no issues. Dress the cables to the door and door panels so they don't get caught in the window mechanism, and that means the door panels are off.
Old 04-25-2017, 04:56 PM
Bigfoot928
Bigfoot928's Avatar
It's easy, and as everyone else posted you need to get the door panel off.
Old 04-26-2017, 03:51 PM
jtrygstad
jtrygstad's Avatar
When I installed Hans speakers (yes door panels removed), I had a very hard time pulling new wire through the channels since I was using thick KimberKable. Then I took a trip to Home Depot and discovered Klein wire pulling foam lubricant. Great stuff and the foam dissipates in about 10 minutes.
The aerosol can has a long tube you can shove up through the hard plastic channel for applying the foam.
Old 04-26-2017, 07:30 PM
TXBenchRacer
TXBenchRacer's Avatar
it's not so bad no coat hanger no ...lube ....... this probably isn't the best place to say no lube ....
Old 04-26-2017, 08:37 PM
The Forgotten On
The Forgotten On's Avatar
Probably, as it looks really tight.
Old 04-27-2017, 04:05 PM
dr bob
dr bob's Avatar
Continuing the lube theme, you can in fact use your favorite personal lubricant for this task, with no worries about petro-based lubes that might otherwise deteriorate the cable.
Quick Reply: Pulling speaker wire into doors..who dunnit?
