944 & 944S Forum 1982-1991
Clutch Kit Reccomendations - 1985 944
Old 10-20-2017, 06:45 PM
bzlee
6th Gear
bzlee's Avatar
Default Clutch Kit Reccomendations - 1985 944
Hi guys,
Ive been having some clutch problems. When you start from cold it seems to shift but after it heats up, it has issues shifting in and out of gears. I have replaced the slave and master and bled the lines multiple times. Ive ruled out those things. I think it might be the pressure plate. If it is while i have the tranny off and checking the plate i might as well replace the clutch. Do you all have any recommendations on a good OEM replacement?
Thanks,
Old 10-20-2017, 08:50 PM
V2Rocket
Rainman
V2Rocket's Avatar
http://www.rockauto.com/en/catalog/p...lutch+kit,1993
Old 10-20-2017, 09:38 PM
bzlee
6th Gear
bzlee's Avatar
Thanks rocket ! Do you have a preference of those three ? Or any pros or cons of them ?
bzlee
6th Gear
bzlee's Avatar
Many benifit of one vs. the others ?
Old 10-21-2017, 12:13 AM
bzlee
6th Gear
bzlee's Avatar
Is there anything else that should be replaced while the clutch is being replaced ?
Old 10-21-2017, 12:11 PM
RM512
RM512's Avatar
Have your flywheel resurface at a machine shop
Old 10-21-2017, 02:47 PM
924martinirossi
924martinirossi's Avatar
Got mine from Parts Geek
https://www.partsgeek.com/ss/?i=1&ss...clutch&x=0&y=0
A SACHS clutch came in the box marked LuK. it has everything you need to replace including the alignment tool.
Old 10-23-2017, 01:57 PM
V2Rocket
Rainman
V2Rocket's Avatar
SACHS is the OEM for Porsche, quality impeccable.
Old 10-24-2017, 10:32 PM
snb13
snb13's Avatar
The rear main seal!
Old 10-25-2017, 07:59 PM
924martinirossi
My rear main seal was not leaking prior to replacing the clutch and I decided to replace it. Despite following all the procedures the new seal leaked, a little.
I now have a dripan in the driveway!
Quick Reply: Clutch Kit Reccomendations - 1985 944
