944 & 944S Forum 1982-1991
engine installation
Old 10-23-2017, 06:10 PM
zaphodbblbrox
2nd Gear
zaphodbblbrox's Avatar
Default engine installation
installing and engine from the top to an 83 looking for tips and tricks
Old 10-24-2017, 05:49 PM
924martinirossi
924martinirossi's Avatar
I have done a few from the top. I now drop the engine out the bottom. A lot easier.
Michael
Old 10-24-2017, 07:50 PM
JRP944
JRP944's Avatar
Can be done with the hood installed, but certainly offers more clearance if you remove the hood.
Using a load leveler for tilting the engine forward and backward is helpful. A lot of people get away without this, but I found it useful.
Take off the distributor cap and rotor to avoid damaging them.
Remove the fan assembly and the radiator - you’ll need the clearance to slide the engine forward to disengage the clutch from the drive shaft.
Disconnect the cross member to give the oil pan clearance - needed when attempting to slide the engine forward to disengage the drive shaft.
Leave the A/C compressor in the car - disconnect it from the engine before removal.
Justin
Quick Reply: engine installation
